ADUC842/843 BAUD RATE & SUPPLY
I am using ADUC842/ADUC843 controller.Baud rate i need is 460800.
How to achieve this baud rate?
Also i want to know the difference between ADUC842/ADUC843 5V AND ADUC842/ADUC843 3V ....
Regards,
Mayuri
  • ADUC842/843 are single clock devices.
    Given that timers on a standard 8052 are increment by 1 with each machine
    cycle, but on the ADuC841/ADuC842/ADuC843, one machine cycle is equal to one
    clock cycle means therefore the timers are increment at the same rate as the
    core clock.
    So, with a crystal of 29.4912 MHz, SMOD as 0 and TH1 reload as 0xFE the baudrate
    for mode 1 as 8-Bit UART with variable baud rate, equals to 460800 as desired.
    This document describes everything in detail.
    www.analog.com/.../ADUC841_842_843.pdf
  • The ADuC841 and ADuC842 are identical with the exception of
    the clock oscillator circuit. The ADuC841 is clocked directly
    from an external crystal up to 20 MHz whereas the ADuC842
    uses a 32 kHz crystal with an on-chip PLL generating a
    programmable core clock up to 16.78 MHz
    With these frame in mind there is the option to use Timer 3 Generated Baud Rates.
    Using the internal 32768Hz clock crystal PLL locked x512 gives Fcore as 16.777216MHz
    Setting up the appropriate T3 for baud rate generator with
    DIV = 1 (rounded down)
    T3FD = 9 (nearest integer)
    the achieved baud rate is 459649 bits per second,
    as of -0.25% deviation error from the desired 460800.
  • Thnx a lot for the solution.
    Earlier even i had thought to use timer 3 in the same way.
    But after going through the below mentioned site
    ics.nxp.com/.../
    I realized that the maximum baud rate in timer mode in my case is 16777216/64 = 262144 baud rate.
    The baud rate which i want to achieve is 460800 which is obviously larger than 262144.
    pls give me some alternate solution
    Regards,
    Mayuri
  • How to you compare an Analog Devices microcontroller as ADuC842/843
    with NXP microcontrollers for uart setup?
    Please check the formentioned datasheet of ADuC842/843 about Timer3 as baud rate generator.
  • yeah i got it...
    thnx a lot for the help
    regards,
    Mayuri
