usb libs
It important that somebody help me to finish this please,
usb asynchronous
http://www.keil.com/forum/19557/
I took the example posted on this forum and try to put it into this code
here is library
mbed.org/.../USBAudio_8cpp_source.html
#define TOTAL_DESCRIPTOR_LENGTH ((1 * CONFIGURATION_DESCRIPTOR_LENGTH) \
                               + (3 * INTERFACE_DESCRIPTOR_LENGTH) \
                               + (1 * CONTROL_INTERFACE_DESCRIPTOR_LENGTH) \
                               + (1 * INPUT_TERMINAL_DESCRIPTOR_LENGTH) \
                               + (1 * FEATURE_UNIT_DESCRIPTOR_LENGTH) \
                               + (1 * OUTPUT_TERMINAL_DESCRIPTOR_LENGTH) \
                               + (1 * STREAMING_INTERFACE_DESCRIPTOR_LENGTH) \
                               + (1 * FORMAT_TYPE_I_DESCRIPTOR_LENGTH) \
                               + (1 * (ENDPOINT_DESCRIPTOR_LENGTH + 2)) \    // <------------ changed to + (2 *
                               + (1 * STREAMING_ENDPOINT_DESCRIPTOR_LENGTH) )
// Endpoint - Standard Descriptor
        ENDPOINT_DESCRIPTOR_LENGTH + 2,         // bLength
        ENDPOINT_DESCRIPTOR,                    // bDescriptorType
        PHY_TO_DESC(EPISO_OUT),                 // bEndpointAddress
        E_ISOCHRONOUS,                          // bmAttributes
        LSB(PACKET_SIZE_ISO),                   // wMaxPacketSize
        MSB(PACKET_SIZE_ISO),                   // wMaxPacketSize
        0x01,                                   // bInterval
        0x00,                                   // bRefresh
        0x83,                                   // bSynchAddress   <----------- EP3IN
         // Endpoint - Standard Descriptor         // <-------- additional feedback EP
        PHY_TO_DESC(EPISO_IN),                 // bEndpointAddress <---------EPISO_IN
        E_ISOCHRONOUS |  E_ASYNCHRONOUS,      // bmAttributes <------ASYNC
        0x03,                   // wMaxPacketSize <----- 3 bytes
        0x01,                                   // bInterval  <------- 1 packet every frame
        0x01,                                   // bRefresh   <--------2ms
        0x00,                                   // bSynchAddress
Code
// Called in ISR context on each start of frame
extern uint32_t sampling_interval;
void USBAudio::SOF(int frameNumber) {
    uint16_t size = 0;
uint32_t current_timer_count;
 uint32_t feedback_value;
 uint32_t last_timer_count;
 uint16_t interface;
 uint8_t alternate;
                                                        // feedback
  current_timer_count = LPC_TIM1->TC;                   // capture current SOF timing on the Timer1
  if (interface == 1 & alternate == 1) {              // When interface 1 / alt 1 is enabled,
                                                // calculate master/SOF frequency ratio in 10.10 (10.14) format
    feedback_value = ((current_timer_count - last_timer_count) << 14) / sampling_interval;
   //feedback_value = 32 << 14;    // test value for 32k sampling
    USBDevice:: writeNB( EP3IN, (uint8_t *)&feedback_value, 3 );        // and send it to the feedback IN EP
  last_timer_count = current_timer_count;       // update the last SOF timing
Code
int main() {
    int16_t buf[LENGTH_AUDIO_PACKET/2];
    // attach a function executed each 1/FREQ s
    tic.attach_us(tic_handler, 1000000.0/(float)FREQ);
    sampling_interval =  1000000.0/FREQ;
    LPC_SC->PCONP |= (1 << 2);     // Power on Timer'
    LPC_TIM1->TCR = 1;                                       /* TC1 Enable */
    while (1) {
        // read an audio packet
        USBaudio.read((uint8_t *)buf);
        // put buffer in the circ buffer
        for(int i = 0; i < LENGTH_AUDIO_PACKET/2; i++) {
            cbuf.queue(buf[i]);
I am getting Too few arguments in function call
for USBDevice:: writeNB( EP3IN, (uint8_t *)&feedback_value, 3 );
How do I fix this please.
  • "I am getting Too few arguments in function call"
    Hint: How many arguments exist in the example from the link you gave?
  • Ok I change and he update libs
    USBDevice::writeNB(EP3IN, (uint8_t *)&feedback_value, 3, PACKET_SIZE_ISO);
    but at the moment no in transfers are happing, is problem with this I think
    // Set alternate setting. Return false if the alternate setting is not supported
    USBAudio::USBAudio(uint32_t frequency_in, uint8_t channel_nb_in, uint32_t frequency_out, uint8_t channel_nb_out, uint16_t vendor_id, uint16_t product_id, uint16_t product_release): USBDevice(vendor_id, product_id, product_release) {
        mute = 0;
        volCur = 0x0080;
        volMin = 0x0000;
        volMax = 0x0100;
        volRes = 0x0004;
        available = false;
        FREQ_IN = frequency_in;
        FREQ_OUT = frequency_out;
        this->channel_nb_in = channel_nb_in;
        this->channel_nb_out = channel_nb_out;
        // stereo -> *2, mono -> *1
        PACKET_SIZE_ISO_IN = (FREQ_IN / 500) * channel_nb_in;
        PACKET_SIZE_ISO_OUT = (FREQ_OUT / 500) * channel_nb_out;
        // STEREO -> left and right
        channel_config_in = (channel_nb_in == 1) ? CHANNEL_M : CHANNEL_L + CHANNEL_R;
        channel_config_out = (channel_nb_out == 1) ? CHANNEL_M : CHANNEL_L + CHANNEL_R;
        SOF_handler = false;
        buf_stream_out = NULL;
        buf_stream_in = NULL;
        interruptOUT = false;
        writeIN = false;
        interruptIN = false;
        available = false;
        volume = 0;
        // connect the device
        USBDevice::connect();
    bool USBAudio::read(uint8_t * buf) {
        buf_stream_in = buf;
        while (!available || !SOF_handler);
        available = false;
        return true;
    bool USBAudio::readNB(uint8_t * buf) {
        while (!SOF_handler);
        if (available) {
            available = false;
            return true;
        return false;
    bool USBAudio::readWrite(uint8_t * buf_read, uint8_t * buf_write) {
        buf_stream_in = buf_read;
        writeIN = false;
        if (interruptIN) {
            USBDevice::writeNB(EP3IN, buf_write, PACKET_SIZE_ISO_OUT, PACKET_SIZE_ISO_OUT);
        } else {
            buf_stream_out = buf_write;
        while (!available);
        if (interruptIN) {
            while (!writeIN);
        return true;
    bool USBAudio::write(uint8_t * buf) {
        writeIN = false;
        if (interruptIN) {
            USBDevice::writeNB(EP3IN, buf, PACKET_SIZE_ISO_OUT, PACKET_SIZE_ISO_OUT);
        } else {
            buf_stream_out = buf;
        if (interruptIN) {
            while (!writeIN);
        return true;
    float USBAudio::getVolume() {
        return (mute) ? 0.0 : volume;
    bool USBAudio::EP3_OUT_callback() {
        uint16_t size = 0;
        interruptOUT = true;
        if (buf_stream_in != NULL) {
            readEP(EP3OUT, (uint8_t *)buf_stream_in, &size, PACKET_SIZE_ISO_IN);
            available = true;
        readStart(EP3OUT, PACKET_SIZE_ISO_IN);
        return false;
    bool USBAudio::EP3_IN_callback() {
        interruptIN = true;
        writeIN = true;
        return true;
        uint16_t size = 0;
        if (!interruptOUT) {
            // read the isochronous endpoint
                if (USBDevice::readEP_NB(EP3OUT, (uint8_t *)buf_stream_in, &size, PACKET_SIZE_ISO_IN)) {
                    if (size) {
                        available = true;
        if (!interruptIN) {
            // write if needed
            if (buf_stream_out != NULL) {
                USBDevice::writeNB(EP3IN, (uint8_t *)buf_stream_out, PACKET_SIZE_ISO_OUT, PACKET_SIZE_ISO_OUT);
        SOF_handler = true;
    // Set configuration. Return false if the configuration is not supported.
    bool USBAudio::USBCallback_setConfiguration(uint8_t configuration) {
        if (configuration != DEFAULT_CONFIGURATION) {
            return false;
        // Configure isochronous endpoint
        realiseEndpoint(EP3OUT, PACKET_SIZE_ISO_IN, ISOCHRONOUS);
        realiseEndpoint(EP3IN, PACKET_SIZE_ISO_OUT, ISOCHRONOUS);
        // activate readings on this endpoint
        return true;
    bool USBAudio::USBCallback_setInterface(uint16_t interface, uint8_t alternate) {
        if (interface == 0 && alternate == 0) {
            return true;
        if (interface == 1 && (alternate == 0 || alternate == 1)) {
            return true;
        if (interface == 2 && (alternate == 0 || alternate == 1)) {
            return true;
        return false;
    and I think it should be change to this, with interrupt, but after working on your code for so long it hard to for me to understand how this code is working, the interrupt is new to me, and the conflict with alternate.
        uint16_t size = 0;
                                                            // feedback
      if (!interruptIN) {
            // write if needed
                                                     // If interruptIN,
        USBDevice:: writeNB( EP3IN, (uint8_t *)&feedback_value, 3,PACKET_SIZE_ISO);         // and send it to the feedback IN EP
  • Why would this be causing a "integer conversion resulted in truncation" in file "/main.cpp", Line: 19, Col: 40
    // USBAudio
    USBAudio USBaudio(FREQ, NB_CHA, 0x7180, 0x7500);
