function call in branch instruction
i'm using a inline assembler instruction like:
void my_svc_handler(unsigned int * svc_args)
void SVC_Handler(void)
{ __asm{
B my_svc_handler
The problem i have is, that the uVision compiler will not accept the function name "my_svc_handler" after the branch , instruction and comes up with
..\main.c(121): error: #114: label "my_svc_handler" was referenced but not defined
Does anybody know how to correct the syntax that it will work?
Thanks in advance.
  • Hello Scott,
    thanks for your help. It's working now. Was already looking into the instr. Manual, but now i see the difference between
    B loopA // Branch to loopA
    and
    BL func // Branch with link/call to function
    I found this in the CortexM3InstructionSet Examples.
    regards,
    Hermann
