pll and clock setup issue on mcbstm32c
hey,,
>>i want to use usart-2 peripheral on MCBSTM32C and i realised the baud rate set was incorrect, (inspite of right calculations) which was because of the incorrect plck-1 (=112.5Mhz, which should be 36Mhz),, also plck-2 and hclk, system clock set are wrong.
>>for clock setup i'm using SystemInit function from system_stm32f10x_cl.c (i took this from keil's example program.)
>>so i tried running an example prog from keil on the board. i flashed Blinky_ULp into the board ,, but still the same problem of incorrect pclk-1, pclk-2, hclk, sysclk etc persisted,,
please help.. i cant understand why example codes work incorrectly !!!!!
  • 115200 baud? That would be 115.2 KHz
    The bus speed for APB1, 36 MHz
    Confirm USART2->BRR is roughly 0x138
    Make sure HSE_VALUE matches the crystal on the board, and that the PLL/CLK set up is correct. Perhaps you could post what you're actually using within PRE tags
  • Hey ,, thank you very much for ur response..
    >>the exact problem i'm facing is that when i run the code into mcbstm32c, in hardware-debug mode the clock peripherals shows incorrect value for pclk1, pclk2, hclk, sysclk because of which my baud rate is not set correctly.
    i m using uvision 4 .
    >>my hse is enabled and set to 25Mhz
    >>for clock initialisation i call SystemInit() from system_stm32f10x_cl.c and all my clock configuration settings are the same.
    >>the same problem occurs when i burn keil's example code Blinky_ULp into it,, (incorrect hclk, pclk1, pclk2, sysclk)
    >>in the abstract file of this program it says
    Clock Settings: - XTAL = 25.00 MHz - PLL3 = (XTAL/5)*10 = 50.00 MHz - PLL2 = (XTAL/5)* 8 = 40.00 MHz - PLL1 = (PLL2/5)* 9 = 72.00 MHz - SYSCLK = PLL1 = 72.00 MHz - HCLK = SYSCLK = 72.00 MHz - PCLK1 = 36.00 Mhz - PCLK2 = 72.00 Mhz
    >>whereas they are set as: (as shown in clock peripheral of jtag debugger) - XTAL = 25.00 MHz - PLL3 = not shown - PLL2 = not shown - PLL1 = not shown PLL = 225Mhz - SYSCLK = PLL1 = 225.00 MHz - HCLK = SYSCLK = 225.00 MHz PCLK1 = 112.5 Mhz PCLK2 = 225 Mhz
     * Name:    Blinky.c
     * Purpose: LED Flasher for MCBSTM32E
     * Note(s):
     * This file is part of the uVision/ARM development tools.
     * This software may only be used under the terms of a valid, current,
     * end user licence from KEIL for a compatible version of KEIL software
     * development tools. Nothing else gives you the right to use this software.
     * This software is supplied "AS IS" without warranties of any kind.
     * Copyright (c) 2009 Keil - An ARM Company. All rights reserved.
    #include <stdio.h>
    #include <stm32f10x_cl.h>
    #define LED_NUM     8                   /* Number of user LEDs                */
    const unsigned long led_mask[] = { 1UL<<15, 1UL<<14, 1UL<<13, 1UL<<12,
                                       1UL<<11, 1UL<<10, 1UL<< 9, 1UL<< 8 };
    /* Import external functions from Serial.c file                               */
    extern void SER_init (void);
    /* Import external variables from IRQ.c file                                  */
    extern volatile unsigned short AD_last;
    extern volatile unsigned char  clock_1s;
    /* variable to trace in LogicAnalyzer (should not read to often)              */
           volatile unsigned short AD_dbg;
      Function that initializes ADC
    void ADC_init (void) {
      RCC->APB2ENR |= (1<<4);               /* enable periperal clock for GPIOC   */
      GPIOC->CRL &= ~0x000F0000;            /* Configure PC4 as ADC.14 input      */
      RCC->APB2ENR |= (1<<9);               /* enable periperal clock for ADC1    */
      ADC1->SQR1    = 0x00000000;           /* Regular channel 1 conversion       */
      ADC1->SQR2    = 0x00000000;           /* Clear register                     */
      ADC1->SQR3    = (14<< 0);             /* SQ1 = channel 14                   */
      ADC1->SMPR1   = ( 5<<12);             /* sample time channel 14 55,5 cycles */
      ADC1->CR1     = (1 <<  8) |           /* Scan mode on                       */
                      (1 <<  5) ;           /* EOC interrupt enable               */
      ADC1->CR2     = (1 << 20) |           /* Enable external trigger            */
                      (7 << 17) |           /* EXTSEL = SWSTART                   */
                      (1 <<  0) ;           /* ADC enable                         */
      ADC1->CR2    |= (1 <<  3);            /* Reset calibration                  */
      while (ADC1->CR2 & (1 << 3));         /* wait unil reset finished           */
      ADC1->CR2    |= (1 <<  2);            /* start calibration                  */
      while (ADC1->CR2 & (1 << 2));         /* wait unil calibration finished     */
      NVIC_EnableIRQ(ADC_IRQn);             /* enable ADC Interrupt               */
      Function that initializes LEDs
    void LED_init(void) {
      RCC->APB2ENR |= (1<<6);               /* Enable GPIOE clock                 */
      GPIOE->CRH    = 0x33333333;           /* Configure the GPIO for LEDs        */
      Function that turns on requested LED
    void LED_On (unsigned int num) {
      GPIOE->BSRR = led_mask[num];
      Function that turns off requested LED
    void LED_Off (unsigned int num) {
      GPIOE->BRR = led_mask[num];
      Function that outputs value to LEDs
    void LED_Out(unsigned int value) {
      int i;
      for (i = 0; i < LED_NUM; i++) {
        if (value & (1<<i)) {
          LED_On (i);
        } else {
          LED_Off(i);
      MAIN function
    int main (void) {                       /* Main Program                       */
      short AD_value, AD_print;
      SystemInit();
      SysTick_Config(SystemFrequency/100);  /* Generate interrupt each 10 ms      */
      LED_init();                           /* LED Initialization                 */
      SER_init();                           /* UART#1 Initialization              */
      ADC_init();                           /* ADC Initialization                 */
      while (1) {                           /* Loop forever                       */
        if (AD_value != AD_last) {          /* Make sure that AD interrupt did    */
          AD_value = AD_last;               /* not interfere with value reading   */
          AD_dbg   = AD_value;
        AD_print  = AD_value;               /* Get unscaled value for printout    */
        if (clock_1s) {
          clock_1s = 0;
          printf ("AD value = 0x%03x\n\r", AD_print);
  • hey,,,
    the chip on board is stm32f107vc, which is the connectivity line device of stm32f1..
    the problem i think present is in hardware debug of keil,in which the dialogue for reset clock control (in peripherals) is not for connectivity line devices,,, but for the others...
    i think so because :
    (1)it doesn't even show rcc_cnfg2 register which is present only in connectivity devices of stm32f1.... !!
    (2) it shows setting of only 1 pll in debug (pll),, whereas connectivity line devices have 3 plls(pll1, pll2, pll3)
    ( and others have only 1 pll)
    what should i do to update the dialogue box ????
  • I was actually thinking about the PLL, but never mind, I can review the original source in my tree.
    Can you confirm the physical values in RCC CFGR/CFGR2/CR? Or the clocks via the MCO pin?
    Perhaps the decoder is the issue and not the one for a 105/107 series part, but rather a 100/103
  • hey,,
    how do i check physical value of the registers rcc_cr, cngf, cngf2 ??
    and yes,, i can check mco,, i will do that and reply here in the morning,,
    thank you for your response. :)
  • I had a similar issue and it was due to the HSE clock rate being defined twice and not picking up what I thought I had programmed
    On the IDE and project settings its defined and you can also set this with a #define on either the systeminit file so make sure its not picking up the file in keil\arm\rv31
    search for the HSE in your code and see if you can find a conflict in what you set
  • Place a Memory View window over the RCC register space.
