Hi all, I´m using the STM32F103 µC on MCBSTM32 Board. I´d like to get a Sampling frequency of 20kHz for continuous scanning of one channel with ADC1 (channel 3) in DMA mode. For ADCCLK = 0.28MHz 1.5 Cycles (+12.5) should be the correct nr of cycles!? ( 14 cycles * 1/0.28MHz = 50 µs)
Or do I missunderstand something?
Any help would be appreciated.
The datasheet says that there is a minimum ADC clock frequency of 0.6 MHz. You risk ADC performance degradation if you violate it. You can try and stretch the sampling time. Or use a timer as an ADC trigger. The latter is the most flexible approach.
I´d like to get a Sampling frequency of 20kHz .... The datasheet says that there is a minimum ADC clock frequency of 0.6 MHz
and, after all, what's the probllem with a slightly higher samplng frequency.
Thanks a lot for your answers!
@Erik I do undersampling and need exactly this frequency due to given conditions.
