OPtimization of constants with keil
In my code I have many of constants have same value. I cannot use same name of constant due to logic.
On optimization will keil take different memory of each or same memory.
I am using three setting of optimization:
1. O0
2. Cross + microlib + O2
3. Cross + Time + O3
  • I'm not sure I understand the question, but: the memory location of your constants will be different with each optimization setting, unless you use an attribute to place them at a specific address.
    And the compiler will never "merge" constants that happen to have the same value.
  • I don't know what the C spec says about that, but I wouldn't expect folding constants to be a standard optimization. The compiler doesn't know the purpose of the constant -- it may be changed in a patch.
    But idk.
  • Just to be clear, are you saying constant folding can be applied to constant variables, in addition to constant literals?
    For example:
    void func(void)
       int a = 5;
       int b = a * 3;
    I would expect the optimizer to do the math and assign b = 15;
    Where as:
    const int a = 5;
    void func(void)
       int b = a * 3;
    I would expect the expression "a * 3" to be evaluated at runtime.
    The wikipedia article doesn't mention the second example, with constant variables.
  • Just note that 'const' means different things in C or C++.
    In C++, the language allows it to be used as size of arrays etc. So really full constant folding optimizations all out with better compilers.
  • const int a = 5;
    void func(void)
       int b = a * 3;
    Care to explain what made you form that expectation? I ask because I'm pretty sure that expectation is unfounded. Any C compiler worth having will make 'a' as unmodifiable as it possibly can (read-only page configured in the MMU, or even actual ROM), and perform 'a*3' at compile time.
    There's absolutely no sane reason for a C compiler to expect 'a', as defined, to ever change past compile time, and therefore no reason for it to delay evaluation of a*3 until runtime. You entered a two-way promise, a.k.a. "contract", with the C compiler by flagging a 'const'. The contract is that neither your code, nor the C compiler, will ever modify 'a'.
    If you plan on violating that contract in ways the C compiler has no way of knowing about (e.g. modifying the hex file before burning, or re-flashing at runtime) it is your responsibility to tell the compiler about that by amending the contract. You do that like this:
    volatile const int a = 5;
