TcpNet for LPC3250
I'm using the Embedded Artist LPC3250 board and trying to get it working with RL TcpNet without RTX.
During the call to init_TcpNet() it gets stuck and is continually trying to read the PHY (function static U16 read_PHY (U32 PhyReg)) over and over. I’m using the LPC32_EMAC.c driver module. The Ethernet cable is plugged in and showing activity on its led.
I’m using the TCPD_ARM_L.lib library but don’t get any debug info on the uart. Of course without the crazy expensive RL source it's hard to know where things went wrong.
Any ideas why init_TcpNet() cannot read the PHY?
Anyone have an example RL project for the LPC3250?
Thanks.
  • I guess it get's stuck in init_ethernet() function inside LPC32_EMAC.c driver. This has nothing to do with the library. You can debug it, because you have the source of this driver.
    However, Embedded Artist LPC3250 Board has a different PHY - National DP83848 Ethernet PHY. You will have to modify the driver for this PHY. Originally, LPC32_EMAC.c driver is using LAN8700 PHY.
  • Thanks for the info. You were right and I modified the LPC32_EMAC driver to account for different PHY register mapping and I believe the PHY is now configured correctly. Unfortunately I now have the problem that if I enable MAC interrupts with /* Enable EMAC interrupts. */ MAC_INTENABLE = INT_RX_DONE | INT_TX_DONE;
    I'm getting constant interrupts in lpc32xx_vectors.s, and, the handler address is NULL.
    I would have expected the MAC portion of the driver to be working even with a different PHY. Is there something required to handle ethernet interrupts other than calling init_TcpNet()?
    Any suggestions?
    Thanks.
  • Ugh. It was just a matter of the driver not registering the interrupt handler. Adding the line:
    int_install_irq_handler(IRQ_ETHERNET, interrupt_ethernet);
    solved it.
