For example, the following two lines assign slot 0 to SPI0 IRQ interrupt request(s) and slot 1 to TIMER0 IRQ interrupt request(s): VICVectCntl0 = 0x20 | 10; VICVectCntl1 = 0x20 | 4;
HOW TO GET VALUE OF VIC CHANNEL(10,4)?CAN YOU EXPLAIN ?
How to get _what_ value?
Have you checked the user manual for the processor? Specifically the registers for the VIC? You can enable, and poll, interrupt state for all channels.
TIMER0 Match 0 - 3 (MR0, MR1, MR2, MR3) 4 0x0000 0010 Capture 0 - 3 (CR0, CR1, CR2, CR3)
sir i am also confused. i just want to ask that when we use above code then according to manual slot 1 assign to TIMER 0 . HOW ????????
for example according to second line (Connection of interrupt sources to the Vectored Interrupt Controller (VIC)) VIC CHANNEL # IS 4 AND HEX MASK IS 0X00000010 HOW WE GET THESE TWO VALUES FROM SINGLE CODE VICVectCntl1 = 0x20 | 4;???????????
