I using flash magic to load the hex file format program to the board lpc1769.when I load programs in lpc17xx.cmsis.driver.library exsamples UART-interupt to the board is not problems ,but then when I load other files, the error message. my problem? solution?
WHAT error message
Thanks for the reply error message:Unable to communicate.(in use) Ensure no other applications are using the COM port .Try raising or lowsering the baud rate. I also had to change the baud rate to the lowest but still not
So did you do that?
Thanks for your help i solved my problem. Reload program faster when reconnect.
