I have allocated server-type TCP socket and put it into listen state:
tcp_soc = tcp_get_socket(TCP_TYPE_SERVER, 0, 60, fun_TcpCallBack); if (tcp_soc != 0) { tcp_listen (tcp_soc,PORT); }
Then I have connected with socket using Hyper Terminal.
Now I want to disconnect using tcp_close function. Documentation (http://www.keil.com/support/man/docs/rlarm/rlarm_tcp_close.htm) says that after calling tcp_close socket should go to TCP_STATE_LISTEN. My problem is that after calling this functions TCP socket goes to TCP_STATE_TWAIT state and remains in this state (never goes to TCP_STATE_LISTEN).
What I am wrong?
thx
t.
Do you keep invoking constantly the main_TcpNet() function after closing? I think you need to do it.
Yes, I pool tcp_get_state() and main_TcpNet() in one task.
