ARM: Help with instruction ADD with Operand2
New to ARM and I don't understand why following doesn't work.
Using Cortex-M3,uVision I get the error 'Expecting constant expression'
ADD R1,R2,R3,ASR R4
All instruction references I can find give the form 'ADD Rd,Rn, <Operand2>'
and listed under 'Operand2' is 'Rm LSL Rs' so the 'ASR R4' should be legal.
Any help to clear this up would be appreciated.
  • Cortex-M3: ARMv7-M Architecture with Thumb-2 ISA
    Assembler Syntax for ADD instruction:
    ADD{S}<c><q> {<Rd>,} <Rn>, <Rm> {,<shift>}
    <c>      Condition
    <q>      Qualifier
    <Rd>     Destination register
    <Rn>     Register that contains the first operand.
    <Rm>     Register  that is optionally shifted and used as the second operand
    <shift>  Optional shift applied to value read from <Rm>:
             LSL #<n> | LSR #<n> | ASR #<n> | ROR #<n> | RRX
    Example:
    ADD R1,R2,R3,ASR #4
  • Thanks for that, guess my CORDIC won’t be as fast as I thought it could be now.
