ARM7 big table and printf trick
the task is to place a big( 32kb or more ) table in the flash. and code should access it. i use the scf file to place the table on extern flash
here is my code:
(1-1)table.c
#include "table.h"
const struct Pair able[1000]={
{ 222, 33, 6 },
{ 222, 33, 3 },
// long list
(1-2)access_table.c
#include "table.h"
exten const struct Pair able[1000];
void dosomething(void)
{ // read table contents
(1-3)main.c
#include "access_table.h"
main()
{ dosomething();
the above code work fine.
then i change to place a big while.
(2-3)main.c
main()
{ while(1)
{ dosomething();
//--------------------the program will not run to dosomething(), it dosen's reach the table.
but if i
(3-3)main.c
main()
{ while(1)
{ XX_prinf("somewords"); // XX_printf is the lib function by mcu vendor dosomething();
and place the print function in the dosomething().
-------------then the program should run ok!
so the problem is. with a big table. the program can't run OK, but insert printf, it is ok.
the program can run on other C IDE well. so i think it is the problem for arm and mdk. may be the link process.
so any help kindly form any one of your dear reader??
