SPI Loopback Test failure
I have tried to loop back MOSI and MISO and test.
The code appears to be working sometimes based on the led signals...
This is what I could infer:
1)code is sending a character
2)Code is receiving a character
3)The received character is not 0xff or the looped back character but something else.
Is there a specific clock i need to use for spi?I use 12Mhz and use 1/8 th for spi.
Should I initialize anything for loopback or receive?
The datasheet says read the S0SPSR to clear register before receiving data...how do I do that?
Here is the code for your reference
#include  <lpc214x.h>              //Includes LPC2148 register definitions
void spi_init();                        //To define SPI
void spi_send(char p);
char spi_receive();
int  main(void)
        char p='l';
        int i=0,j=0,k=0;
        for(j=0;j<12000;j++)
                                        for(k=0;k<1000;k++);
   PINSEL0 = (1<<8)|(1<<10)|(1<<12)|(1<<14);                // Enable MISO MOSI SCK and Slave Select
   PINSEL1 = 0x00000000;
   PINSEL2 = 0x00000000;
         IO0DIR = (1<<14);
         IO0SET |=(1<<14);
   IO1DIR = (1<<19) | (1<<18) | (1<<17) | (1<<16);
                spi_init();                                     //Initialize spi
        while (1)
                spi_send('0');
        //Send a character and receive the same character
                while(p!='0')
                        p=spi_receive();
                        if(p==(char)0xff)
                                IO1CLR=(1<<19)|(1<<18)|(1<<17)|(1<<16);                 //to check if no data is received without interrupt flag
                while(p=='0')
                        IO1CLR=(1<<19)|(1<<18)|(1<<17)|(1<<16);                         //if data is received properly
                        IO1SET=(1<<19)|(1<<17)|(1<<16);
                        while(1);
void spi_init()
        S0SPCR|=0x20;         //Master Mode
        S0SPCCR=0x8;
        IO0CLR |=(1<<14);
        S0SPDR = p;
  while ((!S0SPSR & 0x80));
        S0SPSR &=~ 0x80;
        IO0SET |=(1<<14);
char spi_receive()
        char p;
        IO0CLR |=(1<<14);
        S0SPDR=0xff;
        IO1SET=(1<<18)|(1<<17)|(1<<16);     //to check if function is entered
        p=S0SPDR;
        IO1SET=(1<<19)|(1<<17)|(1<<16);     //to check if data is received
        return p;
        IO0SET |=(1<<14);
Any help is gratefully appreciated.
Thank You
