addition problem
Recently I have come across a question on bits additions.
Maximum bits in register is 32 bits.
I want to perform 4 different 8 bit parallel additions in a single 32bits.
How do I actually detect, process the overflow and put into my result?
For example, {in hexadecimal}
In a loop,
R0 changes value after each loop, R1=#0 initially,
R1(new) is R1(old) + R0
when loop ends, I want to take into account of the overflow,
return R1 into 4 separate 8 bits for the sum. { R1=aabbccdd }
R1a= aa+overflow a
R1b= bb+overflow b
R1c= cc+overflow c
R1d= dd+overflow d
Thank you very much
Regards,
Pei
  • You did not specify which chip you are using. NXP chips have an overflow indicated in their CPSR register.
  • Thank you for your reply, I am using LPC2013.
    But I am trying to detect ''internal'' overflow when doing 4 parallel addition in a 32 bits
    i.e. I ''fragment'' it into AABBCCDD in hexadecimal Then intend to keep track of DD(old)+DD(new)and it's Overflow to C
  • Keeping track of individual overflows is only possible if the processor has special SIMD instructions (single instruction multiple data) where the processor can see a single 32-bit register as two 16-bit numbers or 4 8-bit numbers. But even then, the processor would normally not support multiple add operations while retaining any multi-number carry values.
    A carry is normally just a single flag. It tells if the last operation did overflow or not. And this flag is then used as input parameter for an add-with-carry, that optionally adds in this carry bit when adding more significant parts of the number. But after that add-with-carry, the carry flag is once more regenerated.
    So carry flags can't handle a+b+c+d+e+f and then check if you got an overflow.
    Some DSP processors have special add instructions where you as input can have a 32-bit register containing four 8-bit numbers and as output get a 64-bit result containing four 16-bit values.
    This allows the DSP to loop through a vector of 8-bit quads and add them and get a result that has room for 256 add operations in a row before each individual sum may overflow.
  • I want to perform 4 different 8 bit parallel additions in a single 32bits.
    And did you even begin to think about whether this is even possible on whichever CPU you're actually using --- a slection which coincidentally you didn't even bother to tell us about?
    You don't. If at all, the CPU might do that.
