P89V664 Serial Graphical LCD Problem
Hello
I have confused in the coding of the Serial Graphical LCD on NXP P89V664.
Can any one help ????
the code is
#include<reg52.H>
#include<stdio.h>
#include<intrins.h>
// #define unsigned char unsigned char // 0~255
// #define unsigned int unsigned int   // 0~65535
sbit _CS = P2^3;
sbit _RST = P2^2;
sbit A0 = P2^1;
sbit SCK = P4^0;
sbit DIN = P4^2;
unsigned char ContrastLevel;     // for contrast setting level
// dispaly data (128x64)
unsigned char code Logo[]={
....0x15,0x06,0x00,0x00,0x10,0x1F,0x10,0x00,0x00,0x12,0x15,0x15,0x15,0x88,0xC0
// Delay Routine
void delayms(unsigned int m)        // 12MHz Xtal, close to ms value
    unsigned int j;
    unsigned int i;
    for(i=0; i<m; i++)
        for(j=0; j<109; j++)
            _nop_();
// IO Routine
void lcd_cmd(unsigned char Command)       //send command
    SCK = 1;
    A0  = 0;
    _CS = 0;
    DIN = Command & 0x80; SCK= 0; SCK= 1;
    DIN = Command & 0x40; SCK= 0; SCK= 1;
    DIN = Command & 0x20; SCK= 0; SCK= 1;
    DIN = Command & 0x10; SCK= 0; SCK= 1;
    DIN = Command & 0x08; SCK= 0; SCK= 1;
    DIN = Command & 0x04; SCK= 0; SCK= 1;
    DIN = Command & 0x02; SCK= 0; SCK= 1;
    DIN = Command & 0x01; SCK= 0; SCK= 1;
    _CS = 1;
void lcd_data(unsigned char DData)        //send data
    SCK= 1;
    A0  = 1;
    _CS = 0;
    DIN = DData & 0x80; SCK= 0; SCK= 1;
    DIN = DData & 0x40; SCK= 0; SCK= 1;
    DIN = DData & 0x20; SCK= 0; SCK= 1;
    DIN = DData & 0x10; SCK= 0; SCK= 1;
    DIN = DData & 0x08; SCK= 0; SCK= 1;
    DIN = DData & 0x04; SCK= 0; SCK= 1;
    DIN = DData & 0x02; SCK= 0; SCK= 1;
    DIN = DData & 0x01; SCK= 0; SCK= 1;
    _CS = 1;
// Write a Screen
void WriteScreen(unsigned char *DisplayData)    // DisplayData should be 164x64/8 = 1312byte
    unsigned char TempData;
    unsigned char i, j;
    for(i=0;i<8;i++)
        lcd_cmd(0xb0 | i);    // select page 0~7
        lcd_cmd(0x10);        // start form column 4
        lcd_cmd(0x00);        // (2byte command)
        for(j=0;j<128;j++)
            TempData=(*(DisplayData+(i*128)+j));
            lcd_data(TempData);
// Contrast control
void LCD_Darker(void)
    if (ContrastLevel<0x3F)
        ContrastLevel++;
    lcd_cmd(0x81);            // E-Vol setting
    lcd_cmd(ContrastLevel);   // (2byte command)
void LCD_Lighter(void)
    if (ContrastLevel>0x00)
         ContrastLevel--;
// Init LCD module
void initLCDM(void)
    _RST=1;                 // hardware reset LCD module
    _RST=0;
    delayms(1);
    _RST=1;
    delayms(800);
    ContrastLevel=0x17;     // default Contrast Level  1a
    lcd_cmd(0xab);                      //new
    lcd_cmd(0xaf);            // display on
    lcd_cmd(0x40);            // display start line=0
    lcd_cmd(0xc8);            // Common output mode select= reverse
    lcd_cmd(0xa6);            // normal display
    lcd_cmd(0xa4);            // Duisplay all point = off
    lcd_cmd(0xa3);            // LCD bias = 1/9   a2
    lcd_cmd(0x2f);            // Power control = all on
    lcd_cmd(0x25);            // Rab Ratio     26
// Main Program
void main()
    SP=0x60;
    EA = 0;         // disable interrupts
    _CS    =1;
    _RST   =1;
    A0     =1;
    SCK   =1;
    DIN    =1;
    initLCDM();
    WriteScreen(Logo);
    while(1)
//end of program
The error it shoes that P4 is an undefined identifier. error C202
  • It is obvious that the proper header file is not used.
    Instead of
    #include <reg52.H>
    use the
    http://www.keil.com/dd/docs/c51/philips/p89v66x.h
    #include <p89v66x.h>
    that is suitable for NXP P89V664. In this file the fifth port P4 (4bit) of this microcontroller is defined as
     sfr P4            = 0xA1;
  • The same thing gives the error for the solution given by you, it is already done by me,...
    Build target 'Target 1'
    assembling STARTUP.A51...
    compiling test.glcd.c...
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(13): error C231: 'P0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(24): error C231: 'SP': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(25): error C231: 'DPL': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(26): error C231: 'DPH': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(28): error C231: 'PCON': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(30): error C231: 'TCON': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(32): error C231: 'TF1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(33): error C231: 'TR1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(34): error C231: 'TF0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(35): error C231: 'TR0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(37): error C231: 'IT1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(39): error C231: 'IT0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(41): error C231: 'TMOD': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(43): error C231: 'TL0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(45): error C231: 'TL1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(47): error C231: 'TH0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(49): error C231: 'TH1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(51): error C231: 'P1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(59): error C231: 'T2EX': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(60): error C231: 'T2': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(65): error C231: 'SM0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(67): error C231: 'SM1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(68): error C231: 'SM2': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(69): error C231: 'REN': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(70): error C231: 'TB8': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(71): error C231: 'RB8': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(72): error C231: 'TI': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(73): error C231: 'RI': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(86): error C231: 'P2': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(99): error C231: 'EA': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(103): error C231: 'ET1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(104): error C231: 'EX1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(105): error C231: 'ET0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(106): error C231: 'EX0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(110): error C231: 'ET2': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(115): error C231: 'P3': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(117): error C231: 'RD': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(118): error C231: 'WR': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(119): error C231: 'T1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(120): error C231: 'T0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(121): error C231: 'INT1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(122): error C231: 'INT0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(123): error C231: 'TXD': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(124): error C231: 'RXD': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(127): error C231: 'IP': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(133): error C231: 'PT2': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(137): error C231: 'PT1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(138): error C231: 'PX1': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(139): error C231: 'PT0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(140): error C231: 'PX0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(142): error C231: 'T2CON': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(165): error C231: 'RS0': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(166): error C231: 'OV': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(168): error C231: 'P': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(171): error C231: 'ACC': redefinition
    C:\KEIL\C51\INC\PHILIPS\P89V66X.H(172): error C231: 'B': redefinition
    TEST.GLCD.C(8): error C231: 'P4': redefinition
    TEST.GLCD.C(12): error C146: 'P4': invalid base address
    TEST.GLCD.C(13): error C146: 'P4': invalid base address
    TEST.GLCD.C(109): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(112): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(112): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(113): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(113): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(114): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(114): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(115): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(115): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(116): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(128): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(128): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(129): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(129): error C202: 'SCK': undefined identifier
    Target not created
  • C:\KEIL\C51\INC\PHILIPS\P89V66X.H(13): error C231: 'P0': redefinition
    Error like redefinition means that all theese are already defined.
    You should use only one header file, not both reg52.h and p89v66x.h
  • Now It shows only this error on compiling and thanks for the support...
    TEST.GLCD.C(10): error C146: 'P4': invalid base address
    TEST.GLCD.C(11): error C146: 'P4': invalid base address
    TEST.GLCD.C(107): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(110): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(110): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(111): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(111): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(116): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(117): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(117): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(123): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(126): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(126): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(127): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(127): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(130): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(130): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(131): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(131): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(132): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(132): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(133): error C202: 'DIN': undefined identifier
    TEST.GLCD.C(133): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(219): error C202: 'SCK': undefined identifier
    TEST.GLCD.C(220): error C202: 'DIN': undefined identifier
    Target not created
  • sfr         P4     = 0xA1;
    It should be noticed that the fifth port P4(4bit) is not addressed as a bit addressable SFR because the "base address" 0xA1 is not evenly divided by 8. So bit access to this port cannot be done using "sbit" in C language. The bits in P4 have to be manipulated by other means.
    macros can be used to set or clear P4 bits
    #define SCK_bit 0
    #define DIN_bit 2
      P4 |= (1<<SCK_bit);
      P4 |= (1<<DIN_bit);
      P4 &= !(1<<SCK_bit);    // Take care of ! or ~ operator for bits
      P4 &= !(1<<DIN_bit);
    Other options are to use another port like P0, P1, P2, P3 to locate the SCK and DIN pin drivers to GLCD. Also if the GLSD is using an SPI interface the native SPI of the P89V664 can be used.
  • #define SCK_bit 0
    #define DIN_bit 2
      P4 |= (1<<SCK_bit);     // Set SCK bit at P4 port
      P4 |= (1<<DIN_bit);     // Set DIN bit at P4 port
      P4 &= ~(1<<SCK_bit);    // Clear SCK bit at P4 port
      P4 &= ~(1<<DIN_bit);    // Clear SCK bit at P4 port
    more at http://www.keil.com/support/docs/1162.htm
    C51: ACCESSING BITS ON P5 OF PHILIPS 552
  • Note that sbit is a proprietary extension to the 'C' language, provided by Keil's C51 - it is not part of the standard language.
  • After writing this there is a new error....
    TEST.GLCD.C(8): error C129: missing ';' before '|='
    Target not created
  • As you see, this is a typical syntax error.
    Review the code and correct the typo(s).
    If you post the code it should be clear enough where these typo(s) are.
  • this is the code
    #include<stdio.h>
    #include<intrins.h>
    #include<P89v66x.h>
    #define SCK_bit 0
    #define DIN_bit 2
      P4 |= (1<<SCK_bit);     // Set SCK bit at P4 port       <------ line no 8, here error comes
    sbit _CS = P2^3;
    sbit _RST = P2^1;
    sbit A0 = P2^2;
    sbit SCK = P4^0;
    sbit DIN = P4^1;
  • As you can see the "copy - paste" method can not solve any problems, instead creates more.
    Every instruction as SCK = 1; or DIN = 1; or SCK = 0; or DIN = 0;
    has to be replaced accordingly with the bit manipulating istructions:
    SCK = 1; has to be replaced with P4 |= (1<<SCK_bit);
    DIN = 1; has to be replaced with P4 |= (1<<DIN_bit);
    SCK = 0; has to be replaced with P4 &= ~(1<<SCK_bit);
    DIN = 0; has to be replaced with P4 &= ~(1<<DIN_bit);
    another convenient way is to use macro definitions
    #define SCK_bit 0
    #define DIN_bit 2
    #define SCK_set   P4 |= (1<<SCK_bit)
    #define DIN_set   P4 |= (1<<DIN_bit)
    #define SCK_clear P4 &= ~(1<<SCK_bit)
    #define DIN_clear P4 &= ~(1<<DIN_bit)
    ... so insted of
    SCK = 1;
    use the macro
    SCK_set;
    All these are happening because the SCK and DIN pins are connected to a port that is not directly bit addressable (sfr P4 = A1;) using the sbit extention of C (C51)as Andy noted.
  • but the DIN is the pin from where i have to give the input from controller to LCD , so i have to make the DIN pin floating for varying the data
  • One of the first things to do, when designing a circuit, is to evaluate the functionality of all processor pins, and then carefully select a mapping between processor pins and signals to get the most out of the processor.
    It often costs a lot of grief to connect the signals first, and then see what happens.
  • There is a kit on which i am evaluting the program, it has pin connections connected as described by me here,
    it has SDCC compitible commands which are not being executed by the Keil, so I want to convert the program into keil for ease of use
