I have built a board with STM32F050C6, it was ok to link to Keil uVision via STLINK/V2 two days ago. However, Keil uVision cannot recognize the target device now. I tried to link other boards via STLINK, and it has no problem, so it is not the STLINK/USB driver problem; and I can program with this target board via STLINK/V2 with STLINK Utility. Anybody has similar experience like this? I am in urgent debugging my board, pls kindly advise!
BR, KY
... add any new chip to uVision within seconds.
does the above sound ridiculous?, I think so.
However, if you contact Keil and have a licence, they will, probably, send you a version/patch that add your chip in a reasonable time.
... Keil should have added this new part already... http://www.keil.com/dd/chip/6561.htm I can build project with it without any problems... Would it be any possible issues with my board?? hmm... it's giving me some hard time...
Does your application disable the debug pins...?
