Hi
Where function pointer stored? in stack , code segment , Data segment
for example in the following code where fp get stored? how can we know that where the pointer variable stored ?
#include <math.h> #include <stdio.h> // Function taking a function pointer as an argument double compute_sum(double (*funcp)(double), double lo, double hi) { double sum = 0.0; // Add values returned by the pointed-to function '*funcp' for (int i = 0; i <= 100; i++) { double x, y; // Use the function pointer 'funcp' to invoke the function x = i/100.0 * (hi - lo) + lo; y = (*funcp)(x); sum += y; } return sum; } int main(void) { double (*fp)(double); // Function pointer double sum; // Use 'sin()' as the pointed-to function fp = &sin; sum = compute_sum(fp, 0.0, 1.0); printf("sum(sin): %f\n", sum); // Use 'cos()' as the pointed-to function sum = compute_sum(&cos, 0.0, 1.0); printf("sum(cos): %f\n", sum); return 0; }
thanks in advance goran
In terms of storage, a function pointer is no different to any other pointer.
The only difference between a function pointer and any other pointer is what it points to
"how can we know that where the pointer variable stored?"
Why do you want to know where it's stored?
www.catb.org/.../smart-questions.html
Did you really mean to ask where the pointed-to function is stored...?
In this case, it is stored on the stack.
...or a register.
