Strange phenomenon with os_tmr_call( )
Hi All,
I'm experiencing a strange problem where my code would get stuck in os_tmr_call() in the rtx_config.c. My variable OS_TIMERCNT is set to 0 (default) so I'm not using it. The value of the "info" argument passed in is 0. To shed more light to the problem, when the firmware is just running idling then I don't experience this problem. As soon as I start UART send and receive, my code would get stuck in os_tmr_call() after a few seconds.
I'm posting my rtx_config.c for reference and I would appreciate any help or suggestions.
Thanks,
Shane
#ifndef OS_TASKCNT
 #define OS_TASKCNT     4
#endif
 #define OS_PRIVCNT     3
#endif
#ifndef OS_STKSIZE
 #define OS_STKSIZE     50
#endif
#ifndef OS_STKCHECK
 #define OS_STKCHECK    1
#endif
#ifndef OS_TIMER
 #define OS_TIMER       0
#endif
#ifndef OS_CLOCK
 #define OS_CLOCK       1409024
#endif
#ifndef OS_TICK
 #define OS_TICK        10000
#endif
#ifndef OS_ROBIN
 #define OS_ROBIN       1
#endif
#ifndef OS_ROBINTOUT
 #define OS_ROBINTOUT   5
#endif
#ifndef OS_TIMERCNT
 #define OS_TIMERCNT    0
#endif
#ifndef OS_FIFOSZ
 #define OS_FIFOSZ      16
#endif
#ifndef OS_MUTEXCNT
 #define OS_MUTEXCNT    8
#endif
 *      RTX User configuration part END
#if   (OS_TIMER == 0)                                   /* Timer 0 (RTOS)   */
 #define OS_TID_        2                               /*  Timer ID        */
 #define OS_TIM_        (1 << OS_TID_)                  /*  Interrupt Mask  */
 #define OS_TRV         ((U16)(((double)OS_CLOCK*(double)OS_TICK)/1E6)-1)
 #define OS_TVAL        (OS_TRV - T0VAL)                /*  Timer Value     */
 #define OS_TOVF        (IRQSIG & OS_TIM_)              /*  Overflow Flag   */
 #define OS_TFIRQ()     if (IRQEN & OS_TIM_) SWICFG |= 2;/* Force Interrupt */ \
                        else          force_irq = __TRUE;
 #define OS_TIACK()     SWICFG &= ~2;                   /*  Interrupt Ack   */ \
                        T0CLRI  =  1;                                          \
                        force_irq = __FALSE;
 #define OS_TINIT()     T0LD    =  OS_TRV;              /*  Initialization  */ \
                        T0CON   =  0xC4;
#else
 #error OS_TIMER invalid
#endif
#define OS_IACK()       ;                               /* Interrupt Ack    */
#define OS_LOCK()       IRQCLR  =  OS_TIM_;             /* Task Lock        */
#define OS_UNLOCK()     IRQEN  |=  OS_TIM_;             /* Task Unlock      */ \
                        if (force_irq) SWICFG |= 2;
/* WARNING: Using IDLE mode might cause you troubles while debugging. */
#define _idle_()        ;
static BIT force_irq;
 *      Global Functions
extern void os_clock_interrupt (void);
void os_def_interrupt   (void) __irq;
/*--------------------------- IRQ_Handler -----------------------------------*/
// User Interrupt Functions
//extern __irq void IRQx (void);                 // User IRQx Function
extern __irq void IRQ_Uart (void);
//#define mIRQx       0x00000080                 // User IRQx Mask
#define mIRQ_Uart       0x00004000                 // UART Mask for Aduc702x
__asm void IRQ_Handler (void) {
   // Common IRQ Handler
        PRESERVE8
        ARM
        STMDB   SP!,{R0}                       ; Save R0
        LDR     R0,=__cpp((U32)&IRQSTA)        ; Load IRQSTA Address
        LDR     R0,[R0]                        ; Load IRQSTA Value
//      TST     R0,#mIRQx                      ; Check IRQx Flag
//      LDMNEIA SP!,{R0}                       ; Restore R0
//      LDRNE   PC,=__cpp(IRQx)                ; IRQx Function
      TST     R0,#mIRQ_Uart                  ; Check UART big
      LDRNE   PC,=__cpp(IRQ_Uart)            ; IRQ_Uart Function
        TST     R0,#(SWI_BIT :OR: RTOS_TIMER_BIT) ; Check OS IRQ Flag
        LDMIA   SP!,{R0}                       ; Restore R0
        LDRNE   PC,=__cpp(os_clock_interrupt)  ; OS Clock IRQ Function
        LDR     PC,=__cpp(os_def_interrupt)    ; OS Default IRQ Function
/*--------------------------- os_idle_demon ---------------------------------*/
__task void os_idle_demon (void) {
  /* The idle demon is a system task, running when no other task is ready */
  /* to run. The 'os_xxx' function calls are not allowed from this task.  */
  for (;;) {
  /* HERE: include optional user code to be executed when no task runs.*/
/*--------------------------- os_tmr_call -----------------------------------*/
void os_tmr_call (U16 info) {
  /* This function is called when the user timer has expired. Parameter  */
  /* 'info' holds the value, defined when the timer was created.         */
  /* HERE: include optional user code to be executed on timeout. */
/*--------------------------- os_error --------------------------------------*/
void os_error (U32 err_code) {
  /* This function is called when a runtime error is detected. Parameter */
  /* 'err_code' holds the runtime error code (defined in RTL.H).         */
  /* HERE: include optional code to be executed on runtime error. */
  for (;;);
void os_def_interrupt (void) __irq  {
  /* Default Interrupt Function: may be called when timer ISR is disabled */
  OS_IACK();
#include <RTX_lib.c>
