Below is a sample code for main.c, which writes 3 different SFR locations with various values. What I noticed, and don't have explanation for, is that when the data is >7Fh, the _rbyte reads it as double, not char.
main.c
#include <REG51XC.H> sfr SFR_REG1 = 0xF8; sfr SFR_REG2 = 0xF9; sfr SFR_REG3 = 0x91; void main (void) { SFR_REG1 = 0x01; SFR_REG1 = 0x11; SFR_REG1 = 0x20; SFR_REG1 = 0x30; SFR_REG1 = 0x40; SFR_REG1 = 0x50; SFR_REG1 = 0x60; SFR_REG1 = 0x70; SFR_REG1 = 0x77; SFR_REG1 = 0x80; SFR_REG1 = 0x81; SFR_REG1 = 0xF1; SFR_REG1 = 0xFF; SFR_REG1 = 0x27; SFR_REG2 = 0x01; SFR_REG2 = 0x11; SFR_REG2 = 0x20; SFR_REG2 = 0x30; SFR_REG2 = 0x40; SFR_REG2 = 0x50; SFR_REG2 = 0x60; SFR_REG2 = 0x70; SFR_REG2 = 0x77; SFR_REG2 = 0x80; SFR_REG2 = 0x81; SFR_REG2 = 0xF1; SFR_REG2 = 0xFF; SFR_REG2 = 0x27; SFR_REG3 = 0x01; SFR_REG3 = 0x11; SFR_REG3 = 0x20; SFR_REG3 = 0x30; SFR_REG3 = 0x40; SFR_REG3 = 0x50; SFR_REG3 = 0x60; SFR_REG3 = 0x70; SFR_REG3 = 0x77; SFR_REG3 = 0x80; SFR_REG3 = 0x81; SFR_REG3 = 0xF1; SFR_REG3 = 0xFF; SFR_REG3 = 0x27; while (1) { } }
functions.ini
signal void rbyte_test1 (void) { char mydata; while (1) { wwatch(D:0xF8); mydata = _RBYTE(D:0xF8); printf("0xF8 Read : %x\n",mydata); } } signal void rbyte_test2 (void) { char mydata; while (1) { wwatch(D:0xF9); mydata = _RBYTE(D:0xF9); printf("0xF9 Read : %x\n",mydata); } } signal void rbyte_test3 (void) { char mydata; while (1) { wwatch(D:0x91); mydata = _RBYTE(D:0x91); printf("0x91 Read : %x\n",mydata); } } rbyte_test1(); rbyte_test2(); rbyte_test3();
Here is the output after executing the code :
0xF8 Read : 1 0xF8 Read : 11 0xF8 Read : 20 0xF8 Read : 30 0xF8 Read : 40 0xF8 Read : 50 0xF8 Read : 60 0xF8 Read : 70 0xF8 Read : 77 0xF8 Read : ffffff80 0xF8 Read : ffffff81 0xF8 Read : fffffff1 0xF8 Read : ffffffff 0xF8 Read : 27 0xF9 Read : 1 0xF9 Read : 11 0xF9 Read : 20 0xF9 Read : 30 0xF9 Read : 40 0xF9 Read : 50 0xF9 Read : 60 0xF9 Read : 70 0xF9 Read : 77 0xF9 Read : ffffff80 0xF9 Read : ffffff81 0xF9 Read : fffffff1 0xF9 Read : ffffffff 0xF9 Read : 27 0x91 Read : 1 0x91 Read : 11 0x91 Read : 20 0x91 Read : 30 0x91 Read : 40 0x91 Read : 50 0x91 Read : 60 0x91 Read : 70 0x91 Read : 77 0x91 Read : ffffff80 0x91 Read : ffffff81 0x91 Read : fffffff1 0x91 Read : ffffffff 0x91 Read : 27
Any suggestions ?
Thanks in advance.
No. Double has got nothing to do with this. Signed and unsigned integers, however, do.
What you're seeing is a consequence of your choice of variable type to hold those values in, and your chosen printf() format specifier. Look up what %x actually expects for input and compare it to what you're giving it. Look up the range of 'char' in debugger function. You'll find that there's simply no way your 'char' can hold any value >0x7F.
Lessen to be taken from this: you hardly ever actually want to use un-adorned "char". MISRA C has a rule forbidding it for just this reason.
Thank you very much for the explanation. Changing the type helped.
It's not read as double, simply as a signed long (or integer).
You should definitely read about integer promotion rules.
The fix is to tell printf, that you're dealing with unsigned data. Use ubyte (unsigned char) instead of char.
Also try:
printf("0x91 Read : %hhx\n",mydata);
I'd prefer the output like this, though:
printf("0x91 Read : %#02hhx\n",mydata);
Check the printf(3) manual page of any non-windows operating system to learn how to use printf.
