i want timer program to generate pulse using 10khz frequency
here is my code..is it correct.if wrong plz help me to generate pulse of 10khz .
#include <LPC21xx.H>
void T0isr(void)__irq;
void delay(void)
{ VPBDIV = 0x00000002; //Set pclk to 30 Mhz
PINSEL0 = 0x00000020; //Enable pin 0.2 as capture channel0
T0PR = 0x0000001E; //Load prescaler for 1 Msec tick
T0TCR = 0x00000002; //Reset counter and prescaler
T0CCR = 0x00000005; //Capture on rising edge of channel0
T0TCR = 0x00000001; //enable timer
VICVectAddr4 = (unsigned)T0isr; //Set the timer ISR vector address
VICVectCntl4 = 0x00000024; //Set channel
VICIntEnable = 0x00000010; //Enable the interrupt } int main(void) { IODIR0=0X000000001;
while(1)
{ IOSET0=0X00000001;
delay();
IOCLR0=0X00000001;
delay();
void T0isr (void)__irq
{ //static int value;
//value = T0CR0; // read the capture value
T0IR |= 0x00000001; //Clear match 0 interrupt
VICVectAddr = 0x00000000; //Dummy write to signal end of interrupt
  • What a beautiful example of perfect code.
    I especially like the use of reentrancy with the delay function. A lovely touch.
  • T0PR = 0x0000001E; //Load prescaler for 1 Msec tick
    Why did you hardcode the value?
    0x1E = 30, and you had 30MHz input frequency. Didn't you think 30MHz/1MHz would be more readable?
    And next thing - did you read the text in the datasheet about the T0PR register? Did you then follow up by looking at the example timing diagrams? You sure you should divide by 30?
    Next thing - when you have prescaled down 30MHz to 1MHz you still wanted 10kHz pulse. How? And how do you think two calls to delay() helps you? You seen any code somewhere that makes the processor actually stop and wait into delay() until the required time have passed?
    Finally - do consider following the posting instructions for source code. There are probably lots of errors in the code that no one will spot because no one will care to read garbled code.
