Hi everyone,
I've already spent 3 days trying to get a timer1 interrupt on an aduc7020, without any success
Timer1 init:
IRQCLR = GP_TIMER_BIT; T1CLRI = 0x55; // Clear pending interrupts T1LD = (32768/2)-1; // 32768 clock ticks T1CON = BIT9 + BIT7 + BIT6; // Periodic mode, enable timer, 32768Hz source clock IRQEN = GP_TIMER_BIT; // Enable Timer 1 interrupt
in my main loop:
if(IRQSIG & GP_TIMER_BIT) GP0CLR = (1 << 16 << 6); else GP0SET = (1 << 16 << 6);
perfectly works.
i'm using keil compiler, with the default startup code that clears the I & F flags:
; Enter Supervisor Mode and set its Stack Pointer MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #SVC_Stack_Size ; Enter User Mode and set its Stack Pointer MSR CPSR_c, #Mode_USR IF :DEF:__MICROLIB
my interrupt routine which is never called (led is never set):
void IRQ_Handler(void) __irq { unsigned long IRQSTATUS = 0; IRQSTATUS = IRQSTA; if ((IRQSTATUS & GP_TIMER_BIT) == GP_TIMER_BIT) //Timer 1 interrupt source { T1CLRI = 0x55; } GP0SET = (1 << 16 << 4); //Red on }
and my main code blinking a led
while(1) { GP4CLR = (1 << 16 << 2); for(i = 0; i < 300000; i++) __nop(); if(IRQSIG & GP_TIMER_BIT) GP0CLR = (1 << 16 << 6); else GP0SET = (1 << 16 << 6); GP4SET = (1 << 16 << 2); for(i = 0; i < 300000; i++) __nop(); if(IRQSIG & GP_TIMER_BIT) GP0CLR = (1 << 16 << 6); else GP0SET = (1 << 16 << 6); }
this code works, the led keeps blinking and the other led is set when the irqsig is present. However, the the interrupt setting another led is never launched.
