Could someone write a comprehensive C tutorial specifically aimed at those who are trying to learn C for programming? I think this would help since the wikibooks, and tutorials, among others, are broken/non-existant. this may be the reason that programming in C has declined these past years. (I know its the reason I don't do it in C)
Also, an explanations of the compilers error codes would help.
http://c-faq.com/
"Could someone write a comprehensive C tutorial specifically aimed at those who are trying to learn C for programming?"
I'm a bit curios now. How many are trying to learn C specifically _not_ for programming?
I thought just about all C tutorials in existence was for people wanting to _program_ in C.
The error codes are totally dependant on the used compiler, so no general book/tutorial can cover them. But the errors are directly related to errors in spelling of C keywords or symbols, or errors in the C syntax, or the use of undefined/undeclared symbols. So it doesn't matter what exact texts a specific compiler uses when emitting errors. The first error issued do specify a source code line, and around that line (or maybe one or a few lines above it) there is a error.
And even if some compilers are better than others to describe the detected error, they all still give enough hints that you can normally quite quickly find the error in the source code.
The thing with C is that it is a quite small language. So you can get going quite quickly. But you have to do own work - i.e. try to program and then do the traditional feedback loop with: - write code - compile - read compiler errors - fix errors - repeat
And then the second loop: - write code - compile - testrun - figure out why code doesn't do as expected, aka debug. - fix errors - repeat
Almost all learning, in most areas, contains similar feedback loops, where we learn while correcting our own mistakes. The main part of the learning is actually in the time spent solving problems: - how to convert an idea into a sequence of computer-processable instructions - how to interpret compiler warnings/errors and correct/improve code - how to interpret results as compared to expectations and correct/improve code
So the main part of learning C is not to find a magic compendium with the optimum description of the language. The main part is to spend time, get stuck, solve problem, continue forward.
Might sound dull, but each problem teaches you something, making you able to stay away from similar problems in the future. Initially, a simple flash-LED program may feel hard. But after a while, it will start to feel simple and finally trivial, as you continue to learn and gain experience.
Hmm.. interesting. So you're asking for tutorials that you've already determined don't exist.
And how, exactly, have you determined that "the wikibooks" (whatever that's supposed to be) ", and tutorials" are all, "broken", given that it's pretty much self-evident that you cannot possibly have checked all of them, much less are you in the position to evaluate them meaningfully, since you don't know anything about the subject matter yet?
What else would you learn it for??!
Does this help: blog.antronics.co.uk/.../08
forget the other responses you have been given. you can tell they are sunday afternoon hobbyists.
learn pascal instead and use the pascal c converter and you dont need to learn c. there are great books. cool examples. excellent support forum.
try http://blog.cfrompascal.com
So "johnny chang" - why do you suggest a really awful route to write code?
Because you don't know better, or because you are posting under a false name while trying to send out as much desinformation as possible?
Only a sunday afternoon hobbyist - or a troll - would suggest a route with auto-conversion from one high-level language to another, with some - very few - exceptions.
per westermark, are you always so slow? you think the original poster was real? you think he'll come back?
No, alas we know that a significant number of people who post are trolls. And that figure seems to have increased significantly the last one or two years.
But that does not change a threads hit rate on Google. So it is still meaningful to give a reasonable answer, to take care of other people who happens to finds a thread.
Specific error codes would depend on the particular compiler - so, Please read the manual
For example, http://www.keil.com/support/man/docs/c51/c51_errors.htm
yes, but sometimes its too tempting to fight back. sorry.
