This problem does not occur in Simulation mode. It occurred using the AT91SAM3U-EK using the ULINK Pro JTAG probe.
An automatic variable declared as type 'double' is not being displayed correctly in the watch or local window. Whereas a variable of type 'float' is displayed correctly.
e.g. double x = 1.3; float y = 1.4;
x is displayed as '0' or '1.697596632871e-314' y is displayed as '1.4'
Could it be a problem with TARMSAM3.DLL as I presume DARMSAM3.DLL is used in simulation mode?.
The environment and tools used: uVision: V4.20.03.0 Tool Chain MDK-ARM Professional V4.20 Compiler: ARMCC.exe V4.1.0.644 Linker: ARMLink.exe V4.1.0.644
CPU DLL SARMCM3.DLL V4.20 Dialog DLL DARMSAM3.DLL V1.09 Target DLL BIN\ULP2CM3.DLL V2.50 Dialog DLL TARMSAM3.DLL V1.08
Ulink Pro Device Family Cortex-M Fimware Version V1.50 SW- Checked Port-JTAG Max XClock 1MHZ
Memory Map IROM1 0x80000 0x20000 IRAM1 0x20000000 0x8000
MCLK -48MHZ
