Don't work RL-TCP NET
I want use RL TCPnet on lpc2368. I use it such as this example: www.keil.com/.../rlarm_tn_using_tcpsoc_example.htm
GSM module connect via COM, because, I implemet next functions in my programm:
void init_serial (void)
BOOL com_tx_active (void)
int com_getchar (void)
BOOL com_putchar (U8 c)
I can tested work thouse functions via send AT-command to GSM module - it's OK!
I have two problem:
1. On run, my program hung on call function "init_TcpNet". Why it's may be?
2. If commented "init_TcpNet", programm is run, but functions com_getchar and com_putchar don't call from TCPnet library. Why?
And result of functions "tcp_get_state" is TCP_STATE_SYN_SENT (SYN packet sent to establish a connect) on step 2 and 3 (see "soc_state" in example www.keil.com/.../rlarm_tn_using_tcpsoc_example.htm).
Thank you!
