Suppose i want to switch from armcc compiler to gcc ,but still use uvision ,what is the process to do it ,i mean except changing the toolchain,how can i generate the startup.s file that will work with GCC?
All of the code examples are for armcc , and i dont see any examples for gcc.
Any help?
Thanks Michael
There are many sites that give GCC examples...
I mean on how to switch uvision to gcc,because i changed it ,and its not compiling at all
What do you mean by that?
Do you mean that compiler doesn't even start?
Or you get loads of errors?
Or what?
Have you searched this site for the articles on using GCC with uVision?
Why do you specifically want to use GCC with uVision?
This is the error that i get :
--- Error: failed to execute 'arm-none-eabi-as'
everything is in the correct place,so i dont know why its now working.
I also tried using eclipse + yagarto\codesourcery , but i didnot manage to configure it correctly for some reason
Stuck....
my.st.com/.../Flat.aspx
I managed to make an enviroment with eclipse + codesourcery , i also add the uvision plugin to eclipse,but now i canot download the binary file....
