ADC conversion to volt in MSC1210
I am using Texas instrument MSC1210 microcontroller (with a clock frequency of 3.6864MHz). This controller has a 24 bit sigma delta ADC unit. I am trying to convert the raw ADC values from it into corresponding volts (or mvolts) signals but unable to do so successfully.
My code specifications are,
1) I am using Keil micro compiler version 4.02 and using C language for programming, with follwoing register configurations
- ADMUX = 0x08; // Differential input from channels AIN0(channel 0) and AINCOM (channel 8)
- ADCON0=0x38; //internal voltage source on at 2.5 v, buffer on,PGA 1
- ADCON1=0x00; // bipolar, auto filter, no calibration
- DECIMATION=0x120; // corresponds to 200 samples/second
ACLK = 00; // corresponds to 200 samples/second
From theory, the below menitoned formual should give the correct ADC to signal (volts) conversion,
signal (volts) = ((Raw ADC Value)/ (2^24)) * 2.5V
But in practice the above formula is not giving me the right volts output and is giving a very small value.
While on the other hand I am using the data sheet formual to convert ADC to volts, as follows
(from application note for ADC (SBAA097B page 13) of MSC1210, bits to volts conversion)
volts = ((N * Vref)/(GC*0.75*DEC^3*BG)) * RawADC + (Vref/(0.75*DEC^3*BG)) * Offset
OR
volt = K1 * RawADC + K2 * Offset................(1)
(N*Vref)/(GC*0.75*DEC^3*BG) = k1
(Vref/(0.75*DEC^3*BG)) = K2
Where (from the same application note)
N = 2^22 (for bipolar case and N = 2^21 for unipolar case)
Vref = 2.5 volts (reference voltage)
GC = 3143213 (gain calibration)
DEC = 288 (decimation for Vs located in Decimation = ADCON2:ADCON3 registers)
BG = 2^-2 (bit shift gain)
Offset = Offset Calibration (OC) register value = 13 (almost the same value of 13 comes up everytime during program execcution).
This evaluates the values of constant K1 and K2 as,
K1 = 0.0000007448132019
K2 = 0.0000005581632945
Hence equation (1) becomes,
volt = 0.0000007448132019 * RawADC + (0.0000005581632945 * 13)
volt = 0.0000007448132019 * RawADC + 0.00007256122................(2)
If I use (2) in my calculation, the rms values of an AC signal is calculated very accurately always. But by right, ADC show give the PEAK (or instantaneous) values of the AC signal not the RMS values.And the ADC values never reaches to reflect the peak value of the AC signal, rather stay near the rms value of the signal.
I have used both ways for ADC conversion but still not able to get the values.Please highlight if there is any thing incorrect I am doing in my calculations and/or registers configurations.
Asad
  • Well, too much to read but remember that the formula:
    requires you to have converted (for example with a type cast) your raw ADC value into a floating point number, before the division. Because else you take the raw integer value and shift it right 24 steps. What will then be left to multiply with 2.5?
    If you start by multiplying with 2.5, then you get your conversion to floating point. Then perform the division.
    Or perform this as a fixed-point integer calculation, in which case you must also start by a multiplication - or a shift-left first before a division throws away the least siginificant bits and you end up with a final answer in mV or uV or whatever scaling you selected.
    As for getting rms or top-value - that also depends on if there is a low-pass filter function in the analog section. With a fast ADC or a slow ADC with sample-hold, you can capture the top value.
  • Thanks for your reply.
    Yes I am taking care of type casting. Infact I am converting the 24 bit raw ADC values into 32 bit signed long integars, and then dividing with (2^24) factor and then muliplying with 2.5V
    "As for getting rms or top-value - that also depends on if there is a low-pass filter function in the analog section. With a fast ADC or a slow ADC with sample-hold, you can capture the top value"
    Could you please elaborate what you actually meant here?
    Infact there is a low pass filter at the input of the ADC. It has 4 modes,
    - Auto
    - Fast Settling filter
    - Sinc2 filter (sinc - square filter)
    - Sinc3 filter (sinc - cube filter)
    I am using the AUTO mode of the filter, which is actually a combination of all the rest of the filters, because AUTO mode uses
    - Fast Settling filter in first 2 cycles
    - Sinc2 filter in 3rd cycle
    - Sinc3 filter in 4th cycle.
    You mean there is signal loss because of this filter? But I am wondering Why I always I am able to read the ADC values which eventually equals to rms values of the signal. Note that I am working on a very small AC signal ranges from 100 to 700 mV .
  • "Yes I am taking care of type casting. Infact I am converting the 24 bit raw ADC values into 32 bit signed long integars, and then dividing with (2^24) factor and then muliplying with 2.5V"
    How?
    Just moving 24 bits integer value into a 32-bit integer doesn't take care of data types.
    It would still be an integer. If you take the integer value 123456 and divide by the integer value (1^24) you get the value zero.
    Regarding filtering of multiple samples - result depends entirely on the sampling frequency in relation to frequency of input signal.
    Next thing is if there are external filtering in the circuit.
  • Regarding your concern on how I am taking care of type casting, I would like to add that I am typecasting the raw ADC values into 32 bit signed long integer and then printing out these 32 bit values as output and save it in a MS excel file.
    After importing all these 32 bit values in MS excel file, rest all of the calculations (division and multiplication) I am doing in the MS excel file, to avoid any mistake/overflow/typecasting problem.
    While on the other note, my sampling frequency is 200 sample/sec and the frequency of the input signal is 60 Hz.
    Yes there is an external RC filter present just before the point at which I am taking the samples.So you may think it as, the input AC signal first passes through an external RC (R=10K and C = 0.1 uF) filter, then the microprocessor takes samples of the AC signal and passes these samples to ADC unit. Then this same signal goes through the internal RC filter of ADC unit and then finally the signal is saved in ADC counts into the ADRES (ADC result) registers.
    I am pretty sure that I am handling the typecasting well and I am very much interested to learn that how filtering may affect the signal?
    Please advice as per above explanation that if there is an external filter present then how the signal may get affected and secondly how the sampling and input signal frequencies may affect the signal?
  • So - you use Excel for converting from raw ADC values into a voltage. So what is your problem then?
    The ADC has a conversion formula A*x + B.
    Your simpler formula assumes the gain is 1, when you figure out A. The second formula says the gain isn't 1.
    Your simpler formula assumes the offset is zero. The second formula takes into account the offset.
    Have you looked into the values used in the second formula? Where do they come from? What does the datasheet say about them? What is the gain in the ADC? And what is the "gain" resulting from the filtering logic outside/inside the ADC?
    About filtering? No - I think _you_ should spend some time pondering what happens if you send a signal through a filter, and then let the ADC sample the filtered result.
    Do you expect to get the same values as if you sampled an unfiltered signal?
    Don't you think the bandwidth represented by the filter will affect if your ADC can read peak values or RMS values or something in between? Exactly what does a filter do? What happens if you send a signal through a high-passs filter? What happens if you send a signal through a low-pass filter?
  • One thing you should probably start by doing is, if you're getting incorrect values, add a line in front of your voltage calculator that sets the raw ADC value and step through the calculation. Walk through all your calculations until you find out what line is giving you an incorrect value and then break it down until you find what the problem is. If you have a logic problem earlier on, all your data will be skewed.
    For instance, if you have a raw value that is less than 24 bits, you're going to bring it to zero before you can even process the rest of the values. It might be you have an order of operations (maybe you want to scale it by 24 bits AFTER you've added the offset, for example).
    But the best way to move forward is to start to find out exactly where the problem is, try and understand what is going on, try to solve is using a few approaches and, if you're still stuck, then come back here and try and get help. Typically, people in these boards prefer to point you in the right direction rather than just give you the answer as you learn more about the process and you'll be a better programmer for it.
    Good luck!
  • And the ADC values never reaches to reflect the peak value of the AC signal, rather stay near the rms value of the signal.
    are you taking a bunch of samples within one period?
    how do you synchronize you samples to the period?
    what is the frequency of your input?
  • @ Erik:
    Please see below for your queries replies,
    Yes, I am collecting 128 samples of the AC signal and look for the maximum sample value to get the PEAK value of the AC signal.
    Since I am taking 128 samples over 38 cycles of the AC signal, therefore I don't see strong requirement of synchronization of samples to the period.
    My input AC signal frequency is 60Hz. My sampling frequency is 200 sample/sec.
    Just to make it more clear,
    ( Sampling frequency ) 200 samples in 1 sec
    ( 128 samples will take ) 128 samples will take (1/200) * 128 = 0.64 sec
    ( number of AC signal cycles coverage in 0.64 sec are) 60 Hz * 0.64 = 38 cycles (approx)
    How you see the input frequency or sampling frequency may affect the PEAK values collection by ADC?
  • 200 samples/second - means one sample every 5 ms.
    For a 0.5% error, you need to get a sample within arccos(0.995) = 5.7 degrees of a peak or within (5.7/360) * (1/60) = 0.26 ms.
    But let's say your first sample starts (just an example) at a zero crossing.
    Your samples are taken at 0, 5, 10, 15, 20, 25, ... ms.
    The period of the signal is 1/60 s = 16,67 ms.
    So your samples will happen at angles:
    0, 108, 216, 324, 72, 180, 288, 36, 144, 252, 0, 108, ... degrees.
    As you can see, it doesn't matter how many samples you take - you just get an infinite repetition where you get no samples close to 90 or 270 degrees.
    108 degrees is 18 degrees off.
    288 is 18 degrees off.
    cos(18) is 0.95 - so 5% error.
    And your error will be different (but often large) depending on where in the phase you start to take the first sample.
    You either need to sample at a high enough rate that you get close enough for even a single period. Or you need to make sure there isn't any aliasing between sample frequency and signal frequency, so that it is possible to sample for many periods and get some of the samples close enough to a peak.
  • You either need to sample at a high enough rate that you get close enough for even a single period. Or you need to make sure there isn't any aliasing between sample frequency and signal frequency, so that it is possible to sample for many periods and get some of the samples close enough to a peak.
    or include a zero crossing detector.
  • @ Per Westermark
    Thanks Westermark, for your suggestion of looking at the the filter stuff, seems useful to me and shown improvement to my readings/values.
    As per your suggestion, I changed the filter setting from AUTO mode to FAST SETTLING mode, and I am able to see a huge change in my ADC values much closer to the PEAK values but still not close enough to say it accurate.
    Like I am observing an increased change in ADC values (using FAST SETTLING mode) of 75mV(voltage equivalent) as compared to previous filter setting (AUTO mode). But still I am seeing an offset of 50mV to 100mV (voltage equivalent) in my readings as compared to PEAK values of AC signal.
  • @ Per Westermark
    Also I am able to see a difference in - passing a signal through a filter and passing a signal without a filter.
    As I mentioned before that we are using an external filter (R=10k and C=0.1uF) just before the point of taking samples, so for this external filter I calculated the GAIN of the filter which appears to be 0.93, which means that there is a 0.07% signal loss when a sigal passes throgh this external filter. This loss also partially contribute to not able to reach / read the PEAK value of the AC signal.
  • 0.97 does not represent a dampening of 0.07% - it represents 7%.
  • But what have you done about the sampling frequency of the ADC compared to the frequency of the input signal? How do you guarantee that you will get samples close enough to a peak?
  • Sorry, my bad. Yes 0.93 gain of the filter represent the dampening of signal by 7%.
