Compiler Research
According to documentation
RealView Compilation Tools Compiler User's Guide (version 3.1)
Compound literals
int y[] = (int []) {1, 2, 3};
--c90 mode
warning #520-D initialization with "(...)" expected for aggregated object
error #70 incomplate type is not allowed
error #29 expected an expression
--c99 mode
error #144 a value of type "int *" cannot be used to initialize an entity of type "int"
it must be compiled ok, but it is not. What's wrong?
  • You've left off the comment that is in the documentation:
    int y[] = (int []) {1, 2, 3}; // error in strict C99, okay in C99 --gnu
    What you are seeing is consistent with the comment. Some things that are illegal in C99 are nonetheless accepted with --c99 --gnu.
    This usage is legal C99:
    int *yp = (int []) {1, 2, 3};
    This usage is legal in C90, C99 and C++:
    int y[] = {1, 2, 3};
  • Thanks it's work with --gnu compiler directive.
    I don't know what documentation do you read. My sources is:
    infocenter.arm.com/.../index.jsp
    http://www.keil.com/support/man/docs/armcc/armcc_BABECCFG.htm
    And there are no mentions about --gnu option.
    quote from documentation
    ISO C99 supports compound literals.
  • I don't know what documentation do you read.
    I was looking in the Realview 3.1 documentation: infocenter.arm.com/.../index.html
    (which is marked "Superseded" because there are newer versions of the tools)
    My sources is:
    That page also says "Supported in GNU mode for C only." and "Withdrawn" (in the background watermark).
    Compound literals are a C99 feature, but in C99 they cannot be used to initialize arrays that way (which is reasonable since there is a similar, older way to initialize arrays). GNU allows using compound literals to initialize arrays as an extention to C99. And armcc allows the extension when in --gnu mode.
  • ARM C/C++ Compiler
    4.1
    Build 894
    I have some problem with compiler directive --info=totals
    1)when i use it in cmd.exe window it's work fine
    c:\>cd keil450
    c:\Keil450>cd arm
    c:\Keil450\ARM>cd bin40
    c:\Keil450\ARM\BIN40>armcc -c --cpu Cortex-M3 --info=totals c:\src.c
    Code (inc. data) RO Data RW Data ZI Data Debug File Name
    18 0 0 0 0 84 src.o
    2) But if i try to use it with IDE it's not working
    Project Options -> c/c++ -> Misc Controls:
    --info=totals
    Rebuild all
    Build target 'Osilogreph Test'
    compiling system_stm32f10x.c...
    compiling main.c...
    compiling stm32f10x_rcc.c...
    compiling stm32f10x_flash.c...
    compiling stm32f10x_gpio.c...
    compiling stm32f10x_tim.c...
    compiling misc.c...
    linking...
    Program Size: Code=2080 RO-data=320 RW-data=44 ZI-data=1636
    "OSCTest.axf" - 0 Error(s), 0 Warning(s).
    But where is code metrics ???
    maby its don't work with Windows 7 64 bit version
