I am a newbee in Microcontroller programing . the code I have written in C was from a book and it is giving linker error. please help me to solve the problem. I am sending the code:
/*reading pwm waveform and calculation of frequency using microcontroller*/ #include<reg52.h> sbit RS=P2^0; sbit RW=P2^1; sbit EN=P2^2;
sbit IN=P2^4;
void delay(void); void INIT(void); void ENABLE(void); void LINE(int);
int ONTIME(int); int offtime(int); /*declaration of functions complete*/ // void LINE(int i) { if(i==1) { RS=0; RW=0; P1=0x80; ENABLE(); RS=1; } else { RS=0; RW=0; P1=0xC0; ENABLE(); RS=1; } }
/*dealy subroutine*/
void delay(void) { int i,j; for(j=0;j<10;j++) { for(i=0;i<100;i++); } }
/*delay complete*/
/*Enable subroutine*/ void ENABLE(void) { EN=1; delay(); EN=0; delay(); }
/*initialisation of LCD giving proper command*/
void INIT(void) { RS=0; RW=0; EN=0; P1=0x38;// 2 Lines and 5*7 matrix LCD ENABLE(); ENABLE(); ENABLE(); P1=0x06; // Shift cursor to left ENABLE(); P1=0x0E; //display on, cursor blinking ENABLE(); P1=0x01; //clear display screen ENABLE(); } /* measuring ontime*/ int ONTIME(int m) { if(m==1) { IN=1; /*input to 8051 is from 555 osc*/ TMOD=0x01; TR0=0; TF0=0; TL0=0x00; TH0=0x00; while(IN); /*check for rising edge*/ while(!IN); TR0=1; while(IN); TR0=0; }
/* TO MEASURE OFFTIME*/
if(m==2) { IN=1; TMOD=0x01; TR0=0; TF0=0; TL0=0x00; TH0=0x00;
while(!IN); // check for falling edge while(IN); TR0=1; while(!IN); // CHECK FOR RISING EDGE TR0=0; } return((TH0*256)+TL0); }
void main(void) { int unit, tens, hundred, thousand, tenthou, x; char code dis3[]="Fre in HZ="; char *p; int i,j,k,freq,l; while(1) { for(x=1;x<=3;x++) { if(x==1) { i=ONTIME(x); k=i; }
if(x==2) { i=offtime(x); l=i; } if(x==3) { freq=k+1; i=1/freq; } }
unit=(i%10); tens=(i/10)%10; hundred=(i/100)%10; thousand=(i/1000)%10; tenthou=(i/1000)%10; unit=unit+0x30; tens=tens+0x30; hundred=hundred+0x30; thousand=thousand+0x30; tenthou=tenthou+0x30; INIT(); LINE(0);
p=&dis3;
for(j=0;j<8;j++) { P1=*p++; ENABLE(); }
LINE(2); P1=tenthou; ENABLE(); P1=thousand; ENABLE(); P1=hundred; ENABLE(); P1=unit; ENABLE(); } }
What is the exact error message?
You missed the clearly-stated instructions on how to post source code: www.danlhenry.com/.../keil_code.png
Maybe you similarly missed some important instructions in the book...?
And, as already noted, if you want help with an error message then you really need to post the full text of that error message! Use copy-and-paste - do not manually re-type it.
Build target 'Target 1' linking... *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _OFFTIME MODULE: reading PWM waveform using 89s51.obj (READING_PWM_WAVEFORM_USING_89S51) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _OFFTIME MODULE: reading PWM waveform using 89s51.obj (READING_PWM_WAVEFORM_USING_89S51) ADDRESS: 082CH Program Size: data=30.0 xdata=0 code=711 "PWM waveform reading using microcontroller" - 0 Error(s), 2 Warning(s).
When you say that you, "can not find the solution", what efforts have you made to actually look for a solution?
eg, did you look-up the error code in the Linker Manual:
http://www.keil.com/support/man/docs/bl51/bl51_l1.htm
You still have not posted the source code in a legible form; Again, the instructions are quite clear and simple - look at this picture: www.danlhenry.com/.../keil_code.png
You need to make these basic steps if you want people to be inclined to help you...
Note also the link, "Tips for Posting Messages"...
I have recopied it
/*reading pwm waveform and calculation of frequency using microcontroller*/ #include<reg52.h> sbit RS=P2^0; sbit RW=P2^1; sbit EN=P2^2; sbit IN=P2^4; void delay(void); void INIT(void); void ENABLE(void); void LINE(int); int ONTIME(int); int offtime(int); /*declaration of functions complete*/ void LINE(int i) { if(i==1) { RS=0; RW=0; P1=0x80; ENABLE(); RS=1; } else { RS=0; RW=0; P1=0xC0; ENABLE(); RS=1; } } /*dealy subroutine*/ void delay(void) { int i,j; for(j=0;j<10;j++) { for(i=0;i<100;i++); } } /*Enable subroutine*/ void ENABLE(void) { EN=1; delay(); EN=0; delay(); } /*initialisation of LCD giving proper command*/ void INIT(void) { RS=0; RW=0; EN=0; P1=0x38;// 2 Lines and 5*7 matrix LCD ENABLE(); ENABLE(); ENABLE(); ENABLE(); P1=0x06; // Shift cursor to left ENABLE(); P1=0x0E; //display on, cursor blinking ENABLE(); P1=0x01; //clear display screen ENABLE(); } /* measuring ontime*/ int ONTIME(int m) { if(m==1) { IN=1; /*input to 8051 is from 555 osc*/ TMOD=0x01; TR0=0; TF0=0; TL0=0x00; TH0=0x00; while(IN); /*check for rising edge*/ while(!IN); TR0=1; while(IN); TR0=0; } /* TO MEASURE OFFTIME*/ if(m==2) { IN=1; TMOD=0x01; TR0=0; TF0=0; TL0=0x00; TH0=0x00; while(!IN); // check for falling edge while(IN); TR0=1; while(!IN); // CHECK FOR RISING EDGE TR0=0; } return((TH0*256)+TL0); } void main(void) { int unit, tens, hundred, thousand, tenthou, x; char code dis3[]="Fre in HZ="; char *p; int i,j,k,freq,l; while(1) { for(x=1;x<=3;x++) { if(x==1) { i=ONTIME(x); k=i; } if(x==2) { i=offtime(x); l=i; } if(x==3) { freq=k+1; i=1/freq; } } unit=(i%10); tens=(i/10)%10; hundred=(i/100)%10; thousand=(i/1000)%10; tenthou=(i/10000)%10; unit=unit+0x30; tens=tens+0x30; hundred=hundred+0x30; thousand=thousand+0x30; tenthou=tenthou+0x30; INIT(); LINE(1); p=&dis3; for(j=0;j<8;j++) { P1=*p++; ENABLE(); } LINE(2); P1=tenthou; ENABLE(); P1=thousand; ENABLE(); P1=hundred; ENABLE(); P1=tens; ENABLE(); P1=unit; ENABLE(); } }
the error is
Build target 'Target 1' compiling pwm waveform.c... linking... *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _OFFTIME MODULE: pwm waveform.obj (PWM_WAVEFORM) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _OFFTIME MODULE: pwm waveform.obj (PWM_WAVEFORM) ADDRESS: 082CH Program Size: data=32.0 xdata=0 code=747 "PWM waveform reading using microcontroller" - 0 Error(s), 2 Warning(s).
Did you write this code? I doubt that very much! Otherwise, you would have seen that you don't have a function called "offtime" in your code thus the linker error!
No; he didn't - he says he got it from a book!
As noted previously,
"Maybe you similarly missed some important instructions in the book...?"
Does appear to be the case!
Another example that just copying code is not enough - you have to understand it! See: http://www.keil.com/forum/19129/
And have you bothered to look-up the description of that error in the Manual yet?
Again, here is the link: http://www.keil.com/support/man/docs/bl51/bl51_l1.htm
I'll say it again: if you are not capable of writing a given code yourself, it serves no purpose to get it from elsewhere. "transfer of code" invariably will result is something not working and if you are not capable of writing the code yourself, you will be totally lost trying to make the 'found' code work. However, it can sometimes be a shortcut to grab some code and fix it rather than starting from scratch.
If you found that in a book, throw it away and get a better one.
you are right. I have corrected the error. thank you very much
"that" refers to using 'for' loops for timing.
Do not rely on 'for' loops - or, indeed, any othe HLL construct - for timing!
See: www.8052.com/.../182476 And: www.8052.com/.../162556 and many, many more...
""transfer of code" invariably will result is something not working"
that may be a little bit too strong, don't you think?
A little - but not nuch!
Especially with embedded code, it does tend to be so very specific to a particular target & environment that expecting any random piece of cut-&-paste code to "just work" is wishful thinking in the extreme!
