how to clear a single row in 2*16 dot matrix display. i want to clear the only the bottom row in my LCD on MCB2300 board supporting NXP LPC2368 micro controller while retaining the text in the up row . please help me
"i want to clear the only the bottom row in my LCD on MCB2300 board"
Why would this be in any way specific to the MCB2300 board, and/or the NXP LPC2368 micro controller?
Do you suppose that it is a special display - different from all other 2*16 LCD dot matrix displays - designed and manufactured specifically and exclusively for the MCB2300 board, and/or the NXP LPC2368 micro controller?
Isn't it far more likely to be a perfectly standard 2*16 LCD dot matrix display, so that it will work in exactly the same way as any other standard 2*16 LCD dot matrix display on any other board with any other microcontroller?
I AM NOT SPECIFIC ABOUT THE BOARD . BUT I AM NOW USING KEIL BOARD . I JUST WANTED TO KNOW HOW TO CLEAR A SINGLE ROW IN THE ABOVE MENTIONED DISPLAY.
These text displays are very well estabished products, so there's a vast wealth of stuff already out there on the net, in books, etc - have you tried searching?
Have you looked at the LCD controller datasheet?
... the app was not ultra critical, I'd say the heck with it and transmit 16 spaces.
i want real time CLOCK running in row 0 of 2* 16 LCD display it should be working throughout. and i want to just update the data in row 1. so how to clear either row 1 data or either row 0 of the above described display.
Erik has already given the answer.
Go to the row which you want to clear (using address),and then give 16 spaces..
Again, that doesn't sound like anything unusual - have you done any searching yet?
