For those of you who don't know, Greasemonkey is a Firefox addon that allows execution of custom JavaScript for web pages.
Because of the inflation of shouting here, I have written a small script that displays shouting extra small.
// ==UserScript== // @name Anti Shout // @namespace kamikaze.bsdforen.de // @include http://www.keil.com/forum/* // @description Scale down excessive shouting on the Keil forums // ==/UserScript== var tables = document.getElementsByTagName("table"); var table; for (var i = 0; i < tables.length; i++) { if (tables[i].getAttribute("class") == "thd") { table = tables[i]; break; } } function descent(node) { if (node.data) { var volume = node.data.match(/[A-Z]/g); if (volume && volume.length / node.data.length > 0.5) { node.parentNode.style.fontSize = "x-small"; } } for (var i = 0; i < node.childNodes.length; i++) { descent(node.childNodes[i]); } } descent(table);
Brilliant !
I'm afraid to say it's a little buggy. descent(table) might be executed without table being set.
The bug doesn't cause any problems, but still:
// ==UserScript== // @name Anti Shout // @namespace kamikaze.bsdforen.de // @include http://www.keil.com/forum/* // @description Scale down excessive shouting on the Keil forums // ==/UserScript== function descent(node) { if (node.data) { var volume = node.data.match(/[A-Z]/g); if (volume && volume.length / node.data.length > 0.5) { node.parentNode.style.fontSize = "x-small"; } } for (var i = 0; i < node.childNodes.length; i++) { descent(node.childNodes[i]); } } var tables = document.getElementsByTagName("table"); for (var i = 0; i < tables.length; i++) { if (tables[i].getAttribute("class") == "thd") { descent(tables[i]); } }
This update gets rid of a false positive condition.
// ==UserScript== // @name Anti Shout // @namespace kamikaze.bsdforen.de // @include http://www.keil.com/forum/* // @description Scale down excessive shouting on the Keil forums // ==/UserScript== function descent(node) { var length = 0; var shouted = 0; for (var i = 0; i < node.childNodes.length; i++) { var child = node.childNodes[i]; if (child.data) { var caps = child.data.match(/[A-Z]/g); length += child.data.length; if (caps) { shouted += caps.length; } } else { descent(child); } } if (length && shouted / length > 0.5) { node.style.fontSize = "x-small"; } } var tables = document.getElementsByTagName("td"); for (var i = 0; i < tables.length; i++) { if (tables[i].getAttribute("class") == "bod") { descent(tables[i]); } }
you could get Keil to incorporate it.
Incorporating it locally will have no effect on the IDIOTs screen.
Sadly, the days when you could break into a company's web service without repercussions, as long as you didn't do any real harm, are long over.
I was afraid something like this would happen (false positives): http://www.keil.com/forum/21786/
Though I expected it from preprocessor examples.
What should I do about it, any ideas?
what in the thread you link to do you consider a false positive?
If you use my script 2 blocks of ASM code are affected. I don't consider assembler code shouting.
Is that due to the total lack of comments?
You could say so.
in that case it would probably be OK to 'minimize'
Good point, I am appeased.
