Why error in mutline macro here:
#define MCP_SPI_CONFIGURE { \ LPC_IOCON->PIO0_6 = 0x82; /* ssp0 clk config */ \ LPC_IOCON->PIO0_8 = 0x81; /* ssp0 miso config */ \ LPC_IOCON->PIO0_9 = 0x81; /* ssp0 mosi config */ \ } #define MCP_CS_CONFIGURE { \ LPC_IOCON->PIO1_26 = 0x00000080; /* GPIO pin used for chip select */ \ LPC_GPIO->DIR[GPIO_PORT_1] |= GPIO_BIT_26; /*set bit 2 as output */ \ LPC_GPIO->SET[GPIO_PORT_1] = GPIO_BIT_26; /*set bit 2 high i.e diable chip */ \ }
Look at the Preprocessor output to see what's actually happening...
Judging by the recent posting patterns, it looks like a certain poster has just got round to reading up on the preprocessor.
Code don't build. It gives error like: parsing starts , expected an expression, expexted a "}".
Remember, the compiler only sees the output from the preprocessor.
So, again, look at the Preprocessor output to see what's actually happening...
http://www.keil.com/support/man/docs/uv4/uv4_dg_adslst.htm
c-faq.com/.../multistmt.html
You've got spaces behind the backslashes. The backslashes are supposed to escape the line feed, there may not be any spaces behind them.
Thanks, that was error.
