I'm using 'LPC1788 Developer's Kit', i can't send data to my PC via RS232 port (URAT1).I tried some examples like Blinky, but nothing appears in my HyperTerminal.What could be the problem ? please help!
Bad software. Bad hardware. Incorrectly assumed baudrate. Incorrect/broken cable. Incorrect configuration of software (what crystal etc) Incorrect configuration of the board (straps etc) Software not correctly downloaded into platform. Wrong RS-232 port used on the board. Broken serial port on PC, or broken USB-to-serial adapter. ...
So what have you done to try to figure out what works and what doesn't work?
I have RS232 port on both: board and PC, so there's no USB-to-serial adapter. The cable's fine. I have one RS232 port. My ULINK works fine. The board is configurated correctly. The software is made for this board, so i think it should work correctly without changes. I don't know what could be wrong because it still no response.
Are you using the NXP SPL? Then take a look at this:
forums.nxp.com/viewtopic.php
Maybe they haven't corrected it yet. I had the same experience: examples would not work on the demo board.
Made me go away from NXP.
