Problem in Code, need Help
i want help regarding this code, the do-while loop inside "in Bold" is completely ignored, i inserted dummy subroutines inside to see where the execution was going but all i could see was the parent do-while Loop in italics that was being executed again and again.
note: the Parent do-while is intended to be superlooped, but the do-while (in bold) is for cheking the Password and displaying the Lock Screen which is not being executed, after displaying
Home_Screen();
the program waits for the input by the statement while(Keypad_Input() == False);
and after that it never enters the do-while loop.
in short the Code Between the Stars is not Executed
void Start()
         Lock_State = Closed;
        do
                Home_Screen();
                 while(Keypad_Input() == False);// Wait for a key to be pressed.
        do{
                        Lock_Screen();
                        Keypad_Instance(5,2,8,0,'C'); // 5 character password at pos 2,8, Hidden and 'C' is the break Character
                        Check_Lock1();   //Check the Password, if true then Lock_State=Open
                        if(Lock_State == Open)// Lock is Open
                                  break;
                        else
                                LCD_Cursor_XY(3,7);
                                LCD_Text("RETRY !!!");  //on entering Wrong Password
         }while(Lock_State == Closed);
                Main_Menu1_Instance();
 }while(1);
