I2C interfacing to PCA9532 peripheral
hi everyone im only starting learning about microcomputers so please forgive any mistakes i make.
ARM core, LPC2478 microprocessor, board is the MCB2478.
im trying to communicate via I2C to the PCA9532, specifically a read operation, the write is no problem, my issue is with the repeated start of the read operation. when i simulate the code i the repeated start does not occur and it just writes out last byte of data in the I20DAT register, so clearly i must be doing something wrong. i have been been looking through both the LPC24xx UM and the PCA5932 UM cannot find what i might be doing wrong. if anyone could give me some help would be great. my attempted code is below.
void set_start(void); //set start condition
 /* function to read the input0 register. the input0 register contains the status of LED0 to LED7 on the PCA9532 */
int read_switch(void)
         unsigned char a;                //  ?variable to hold ipunt0 register byte
        /* start condition */
         set_start();
        I20DAT = 0xC0;                                   // address of PCA9532 wit read bit set
        I20CONCLR = I2C_SI|I2C_STA ;     // clear bits
        while (!(I20CONSET & I2C_SI));       // wait
        I20DAT = 0x00;                                   // AI bit clear and input0 register
        I20CONCLR = I2C_SI;                              // clear si bit
        set_start();
        I20DAT = 0xC1;                                   // address of PCA9532 wit read bit set
        I20CONSET = I2C_STO;                     // generate stop bit
        I20CONCLR =I2C_SI;                               // clear si bit
        while (!(I20CONSET & I2C_STO));      // wait
        a = I20DAT;                                              // give the contents of the data register to the variable
        return a;                                                // return that variable
        I20CONCLR = I2C_AA | I2C_SI |I2C_STA |I2C_STO;
        I20CONSET = I2C_STA     ;            // repeated start
