use of uart
I want to transmit three values through uart_putS function. but since the variable that i am passing are char and int type it is showing error as "char" is incompatible with parameter type"char *".
what should i do so that the values that are read and stored in char(int) variable can be transmitted in string format or can be transmitted using uart.
  • What standard functions, in the standard 'C' library, can you think of that take a numeric value as input, and produce a string as a result...?
    blog.antronics.co.uk/.../12
  • Or optionally - what functions takes a pointer to a block of memory, and a size?
  • this is my code:
    i want to transmit the values of function temp(), memx(), memy() and brake() by using gsm() function i am successful for sending the values of longitude and latitude .i have tried many tricks but nothing worked.please give some suggestion what is wrong in this:
    #include<lpc214x.h>
    #include<stdio.h>
    #include<string.h>
    #include "UART.h"
    #define PRESET 0x00210600
    #define ESC 0x1B
    #define DONE 0x80000000
    #define START 0x01000000
    #define buzzer 16
    #define crash 24
    void gsm( void);
    void gps(void);
    char msg[] ; //msg
    char msg1[] ; //msg1
    unsigned char val1,val2,val3,val4;
    unsigned int val5=0 , val0 ;
    unsigned int continuation=0;
    unsigned int k = 0;
    unsigned char Key, Gate;
    unsigned char Buff[50];
    char Latt[16];
    char Long[16];
    unsigned char IE=0;
    unsigned char Flag,Q,ii,pos,j;
    char brake;
    unsigned char temp(void);
    unsigned char memx(void);
    unsigned char memy(void);
    unsigned char memz(void);
    unsigned char vibrate(void);
    unsigned char brakeapplied(void);
    void DelayMs(int);
    void delay(int);
    void serial_isr (void)__irq;
    int main(void)
    { char tem,hor,ver; char vib; unsigned int ADC_CH; unsigned long val[5];
    PINSEL0 |= 0x00000005; PINSEL1 |= 0x01 << 24; PINSEL1 |= 0x01 << 26; PINSEL1 |= 0x01 << 28; PINSEL1 |= 0x01 << 18; PINSEL0 |= 0x00000003 ; PINSEL0 |= 0x00000003;
    VPBDIV = 0x02; AD0CR = 0x00210602; AD0CR |= 0x01000000;
    UART0_Init (9600); UART1_Init (9600);
    U0IER = 1;
    VICIntSelect = 0<<6; VICVectCntl0 = 0x020 | 6; VICVectAddr0 = (unsigned long)serial_isr; VICIntEnable = 0x00000040;
    IODIR1=0x00ff0000;
    ADC_CH = 1;
    while(1) { while (ADC_CH < 7) { do { val[ADC_CH] = AD0GDR; // Read A/D Data Register } while ((val[ADC_CH] & 0x80000000) == 0); //Wait for the conversion to complete val[ADC_CH] = ((val[ADC_CH] >> 6) & 0x03FF); ADC_CH++; delay(10); AD0CR = PRESET | (1<<ADC_CH); AD0CR |= START; } tem= temp(); hor= memx(); ver= memy(); vib= vibrate(); brake= brakeapplied();
    if(ADC_CH >= 7 /*The number of channels used in PS-ARMDPK*/ ) { ADC_CH = 1; AD0CR = PRESET | (1<<ADC_CH); AD0CR |= START;
    if(tem >= 110 && tem <= 130) { IOSET1 = buzzer ; DelayMs(50); DelayMs(50); IOCLR1 = buzzer; DelayMs(50); DelayMs(50);
    if(hor >= 0x55 || ver >= 0x5a ) { IOSET1= buzzer ; DelayMs(50); DelayMs(50); DelayMs(50); DelayMs(50);
    IOCLR1= buzzer;
    DelayMs(50); DelayMs(50); DelayMs(50); DelayMs(50); }
    if(hor >= 0x7f || ver >= 0x7f) { if(vib == 0xff) { IOSET1= crash ; DelayMs(50); DelayMs(50); DelayMs(50); DelayMs(50);
    IOCLR1= crash ;
    DelayMs(50); DelayMs(50); DelayMs(50); DelayMs(50); } }
    if ((IOPIN1 & (1 << 24)) == 0 ) { gps();
    gsm(); while ((IOPIN1 & (1<<24)) == 0); }
    unsigned char temp() {
    unsigned int val0 , t ; U0THR = 0xAB; delay(5); U0THR = 0xB1; delay(5); U0THR = (AD0DR1 >> 6) & 0x03FF;
    val0 = U0THR; t= (val0 *0.48876) ;
    delay(10);
    return(t);
    unsigned char memx() { U0THR = 0xAB; delay(5); U0THR = 0xB2; delay(5); U0THR = (AD0DR2 >> 6) & 0x03FF; delay(5);
    val1 = U0THR; delay(10); return(val1);
    unsigned char memy() { U0THR = 0xAB; delay(5); U0THR = 0xB3; delay(5); U0THR = (AD0DR3 >> 6) & 0x03FF; delay(5);
    val2 = U0THR; delay(10);
    return(val2);
    unsigned char memz() { U0THR = 0xAB; delay(5); U0THR = 0xB4; delay(5); U0THR = (AD0DR4 >> 6) & 0x03FF; delay(5); val3 = U0THR; delay(10); return(val3); }
    unsigned char vibrate() { U0THR = 0xAB; delay(5); U0THR = 0xB5; delay(5); U0THR = (AD0DR5 >> 6) & 0x03FF; delay(5);
    val4 = U0THR; delay(10);
    return(val4); }
    unsigned char brakeapplied() { U0THR = 0xAB; delay(5); U0THR = 0xB6; delay(5); U0THR = AD0DR6 ; delay(5); if(U0THR == 0x1000FFC0 && continuation==0) { val5=val5+1; continuation=1; } if(U0THR != 0x1000FFC0) { continuation=0; }
    delay(10);
    return(val5); }
    void gsm( void)
    U0IER = 0;
    UART1_PutS ("AT+CMGS=\"9176235634\"\r");
    delay(10);
    UART1_PutS ("Vechicle Crashed @ \Lattitude,Longitude,Temperature,xf,yf,brake : ");
    delay(10);
    UART1_PutS (Latt);
    delay(10);
    UART1_PutS (Long);
    delay(10); /*here i want to transmit tem,hor,ver,brake values give any idea */
    UART1_PutC (0x1A);
    delay(10);
    U0IER = 1;
    void gps()
    { if (Flag == 2) { if (Key == 'A' || Key == 'L') { Flag = 1;
    } else { Flag = 0; } }
    if ((Key == 'G' || Key == 'L') && Q == 0) { Flag = 2;
    if (Flag == 1) { Q = 1; Gate = 0;
    Buff[ii] = Key; while (!Gate); ii++; if (ii > 35)//(*(Buff+i) == '*') { IE = 1; U0IER = 0; Q = 0; Flag = 0;
    pos = 13; j = 0; while (j<10) { Latt[j] = Buff[pos]; pos++; j++; } Latt[j] = '\0';
    pos = 25; j=0; while (j < 10) { Long[j] = Buff[pos]; pos++; j++; } Long[j] = '\0';
    strcpy (msg, "Lat: "); strcpy (msg1,"Lon: ");
    j = 0; while (j<10) { msg[j+5] = Latt[j]; msg1[j+5] = Long[j]; j++; }
    ii=0;
    IE = 0; U0IER = 1; } } }
    char Msg;
    if(((Msg = U0IIR) & 0x01) == 0) { switch (Msg & 0x0E) { case 0x04: while (!(U0LSR & 0x20)); while (IE); Key = U0RBR; Gate = 1; break; case 0x02: break; default : break; } } VICVectAddr = 6;
    void delay(int a)
    { int k,l;
    for(k=0;k<=100;k++)
    for(l=0;l<=a;l++);
    void DelayMs(int b)
    { int k,l;
    for(k=0;k<=50;k++)
    for(l=0;l<=b;l++);
  • All I see is random garbled garbage.
    Did you notice the posting instructions for source code?
  • #include<lpc214x.h>
    #include<stdio.h>
    #include<string.h>
    #include "UART.h"
    #define ESC 0x1B
    #define buzzer  16
    #define crash   24
    void gsm( void);
    void gps(void);
    char msg[] ;    //msg
    unsigned int k = 0;
    char Latt[16];
    char Long[16];
    unsigned char IE=0;
    void DelayMs(int);
    void delay(int);
    int main(void)
             char tem,hor,ver,vib,brake;
            VPBDIV  =       0x02;
            AD0CR   =       0x00210602;
            UART0_Init (9600);
            U0IER   =       1;
            IODIR1=0x00ff0000;
            ADC_CH  =       1;
            while(1)
                    while (ADC_CH < 7)
                            do
                            AD0CR   |=      START;
                             tem=  temp();
                             hor=  memx();
                             ver=  memy();
                             vib=  vibrate();
                            gps();
                            gsm();
                            val0 = U0THR;
                            delay(10);
    return(val0);
                            val1 = U0THR;
                            delay(10);
                 return(val1);
                            val2 = U0THR;
                            delay(10);
                 return(val2);
                    val3 = U0THR;
                     delay(10);
         return(val3);
                            val4 = U0THR;
                            delay(10);
                 return(val4);
    void gsm( void)
            U0IER = 0;
                    delay(10);
            UART1_PutS ("Vechicle Crashed @ \n Lattitude,Longitude,Temperature,xf,yf,brake : ");
                            delay(10);
            UART1_PutS (Latt);
                            delay(10);
            UART1_PutS (Long);
                            delay(10);
            UART1_PutC (0x1A);
                            delay(10);
            U0IER = 1;
    void gps()
                    if (Flag == 2)
                                    Flag = 1;
                            else
                                    Flag = 0;
                            Flag = 2;
                    if (Flag == 1)
                            Q = 1;
                            Gate = 0;
                            Buff[ii]        =       Key;
                            while (!Gate);
                            ii++;
                                    IE      =       1;
                                    U0IER   =       0;
                                    Q = 0;
                                    Flag = 0;
                                    pos = 13;
                                    j = 0;
                                    while (j<10)
                                            pos++;
                                            j++;
                                    Latt[j] = '\0';
                                    pos = 25;
                                    j=0;
                                    while (j < 10)
                                            pos++;
                                            j++;
                                    Long[j] = '\0';
                                    j = 0;
                                    while (j<10)
                                            msg[j+5]        =       Latt[j];
                                            j++;
                                    ii=0;
                                    IE      =       0;
                                    U0IER   =       1;
