Hello, I want to call C program from arm assembly program. I written the code as below. Both the code are in different file. Assembly in .s and C code in .c file. When i run the program it will first start to run the C code and assembly code is not executing. Eventhough i am not able to see assembly code in disassembly window. I want to start execution from assembly and wants to call c function from assembly.Device Selected LPC2148. Assembly code: preserve8 export f area |f|, code, readonly import g entry mov r3,#0x05 bl g end C code: int main(){ int a; g();} void g(){} My second question is about entry directive. Here i specified then also its not start to execute from there. Eventhough in different project i specified to area directive and give the entry directive in second area code then also it start to execute instruction from first area. Again i change the code, keep only one area and give the entry directive after some instruction. No change in the execution. Not able to change exection any way. Please give feedback.
if your reset vector point to asembly the C will not work (is not 'initialized')
you can circumvent it by this
void main(void) ( assembler_code(): while (1): }
