TCPNet: problem with recv() and recvfrom()
Hello all!
I'm trying to write simple SNTP client with BSD sockets. I wrote such code:
#include "LPC23xx.h"
#include "uart.h"
#include "RTL.h"
#include "main.h"
#include <Net_Config.h>
//-------- <<< Use Configuration Wizard in Context Menu >>> -----------------
//   <h>Time server IP
//     <o>IP1: Address byte 1 <0-255>
//      Default: 192
#define IP1            192
//     <o>IP2: Address byte 2 <0-255>
//      Default: 168
#define IP2            168
//     <o>IP3: Address byte 3 <0-255>
//      Default: 0
#define IP3            0
//     <o>IP4: Address byte 4 <0-255>
//      Default: 100
#define IP4            13
//   </h>
//------------- <<< end of configuration section >>> -----------------------
OS_TID poolID, timerID, SNTPID;
char rx_buf[150];
U64 tcp_stack[800/8];
U64 SNTP_stack[800/8];
#define MCLK 48000000                         /* Master Clock 48 MHz         */
#define TCLK       10                         /* Timer Clock rate 10/s       */
#define TCNT (MCLK/TCLK/4)                    /* Timer Counts                */
BOOL tick;
U32  dhcp_tout;
BOOL LCDupdate;
extern LOCALM localm[];                       /* Local Machine Settings      */
#define MY_IP localm[NETIF_ETH].IpAdr
#define DHCP_TOUT   50                        /* DHCP timeout 5 seconds      */
void tcp_task (void) {
  /* Main Thread of the TcpNet. This task should have */
  /* the lowest priority because it is always READY. */
        UART2_init(115200);
        init_TcpNet();
        timerID=os_tsk_create (timer_task, 0x20);
        //poolID=os_tsk_create_user (tcp_task, 0, &tcp_stack, sizeof(tcp_stack));
        //os_dly_wait(1000);
        SNTPID=os_tsk_create_user (SNTP_task, 0x02, &SNTP_stack, sizeof(SNTP_stack));
  while (1)
    main_TcpNet();
    os_tsk_pass();
/*--------------------------- timer_poll ------------------------------------*/
void timer_task (void)
  os_itv_set (10);
  while (1)
    /* Timer tick every 100 ms */
    timer_tick ();
    tick = __TRUE;
                os_itv_wait ();
void SNTP_task (void)
        //static int sock;
        int sock;
        int res;
        int addrlen;
        SOCKADDR_IN time_addr;
        char tx_buf[50];
        tx_buf[0]=0x23;                 //SNTPV4 client
        send_string2("SNTP task started\r\n");
        addrlen = sizeof (time_addr);
        while(1)
                sock = socket (AF_INET, SOCK_DGRAM, IPPROTO_UDP);
                if (sock>0)
                        time_addr.sin_port      = htons(5001);
                        time_addr.sin_family    = PF_INET;
                        time_addr.sin_addr.s_b1 = IP1;
                        time_addr.sin_addr.s_b2 = IP2;
                        time_addr.sin_addr.s_b3 = IP3;
                        time_addr.sin_addr.s_b4 = IP4;
                        connect (sock, (SOCKADDR *)&time_addr, sizeof (time_addr));
                        while(1)
                                res = sendto (sock, (char *)&tx_buf, 48, 0,
                                  (SOCKADDR*)&time_addr, addrlen);
                                if (res <0)
                                        break;
                                send_string2("Get-time request sent\r\n");
                                res = recv (sock, rx_buf, 48, 0);
                                if (res <0)
                                  switch (res)
                                        case SCK_EINVALID:
                                           send_string2("socket invalid\r\n"); break;
                                        case SCK_ECLOSED:
                                           send_string2("remote host closed\r\n");
                                           break;
                                        case SCK_EWOULDBLOCK:
                                           send_string2("function would be locked\r\n");
                                           break;
                                        case SCK_ETIMEOUT:
                                           send_string2("timeout\r\n"); break;
                                        case SCK_ELOCKED:
                                           send_string2("function blocked by RTX\r\n");
                                           break;
                                    break;
                                os_dly_wait(300);
                        closesocket (sock);
                        os_dly_wait(300);
                else
                        send_string2("Create socket error!\r\n");
                        while(1);
int main (void)
  os_sys_init_user (tcp_task, 0, &tcp_stack, sizeof(tcp_stack));
where SNTP_task is SNTP client.
Sending request by send() or sendto() functions is good, but functions recv() and recvfrom returns SCK_EINVALID error. When I delete send() function, recv() return error too. I'm tried Keil 4.5 and Keil 4.53.
TCPNet options: two UDP native socket, one TCP native socket, one BSD socket, Receive timeout 20 s.
Thank you.
Andrei
