Place RW Compression Data
is it possible to use a scat file to place the rw compression data?
  • Wouldn't it be the same way you place uncompressed RW data?
    I don't think the fact it is compressed makes it placement in the Load Regio any different.
    The Execute region will obviously need to be large enough for the uncompressed data.
    If you have a scatter file you are working on and want to post it I might be able to explain a little.
    M
  • I don't know how to address the RW compressed data to place it since this is being handled by the linker.
    For example, if I have a simple scat file
    LOAD_ROM 0x0
    { VECTORS +0 { *(.romvectors) }
    CODE +0 { *(+RO) }
    ram execution regions
    the compressed data is placed after the CODE
  • You can use an ANY section.
    For example:
    LOAD_ROM 0x0
    CODE +0 { *(+RO) }
     RAM_EXEC 0xA0000000 0x01000000 ; SDRAM
        .ANY (+RW)
  • so I left out the ram region specification
    RAM_DATA +1 { * (+RW, +ZI) }
    how the compressed RW data (ram initialization data) is not placed in RAM, it is placed in flash (as desired); but I cannot figure out how to specify a region for the compressed RW data (so I control it's location instead of the linker just placing at the end).
  • I think the rw compressed data is actually RO data; I don't know why it is not placed in the CODE execution region.
  • I asked a similar question a while ago:
    http://www.keil.com/forum/16898/
    It also looks like someone asked a similar question and got an answer at:
    http://www.keil.com/forum/17373/
  • thank you!
    I saw that question but I missed the key points:
    the RW compression data is placed in the load region where the compressed data is from so
    adding a second load region correctly places code after the RW compressed data.
  • I don't understand what the Compressed has to do with the placement?
  • @IB Shy - I read your previous question (linked above) I don't understant what you were trying to do. Did you figure it out?
    Based on your original post (desired layout) I don't see why Roger Ivie answer would not have worked?
    The Load address are where the data lives in the image so you can just use as many load regions as you want to place any and all sections. The execution addresses are were the data gets copied/decompressed to.
    I'm obviously not getting something and would appreciate a clarification even if it's just so I can better understand.
    Thanks.
    M
  • when the compressor is enabled, it will compress ram initialization data. This is the data I was calling 'RW compressed data', but it's really RO data the the uncompresseor uses to initialize ram.
    I don't know how to place the 'RW compressed data' explicitly. However, the other post showed that the 'RW compressed data' is placed in the load region it is from, so by creating a 2nd load region, I was able to place data after the automatically placed 'RW compressed data'
    This solves my immediate problem, although I'd still like to know if I can explicitly place the 'RW compressed data'
  • Are you sure that RW compressed data somehow becomes part of the RO section for the linker? I don't think that would make sense?
    Note: I do understand that the RW initialization data must be stored somewhere in the Load Region and my understanding is that this section is referred to as RW (compressed or not)
    Please let me know if this is not your understanding.
    reference:
    infocenter.arm.com/.../index.jsp
  • intuitively that is not my understanding. Since the initialization data will not change, it can be RO.
    primarily I am considering initialization data for static module vars
    simple example
    static uint8 exampleStateFlag = 0x0;
    void exampleStateHandler(void)
      if (exampleStateFlag)
          /* does something */
    that 0x0 has to be stored somewhere and it is not volatile so it seems it should be stored in RO
  • hmm.. That is definitely not my understanding.
    One because it initializes to zero this would probably form part of the ZI section not the RW section.
    Second if it was for example:
    static uint8 exampleStateFlag = 0x77;
    Than I believe that this would be stored in a section called RW. (Otherwise I have no idea what would go in RW sections.)
    Check this link:
    particularly the "area-attrs" section.
  • static uint8 exampleStateFlag = 0x77;
    "Than I believe that this would be stored in a section called RW. (Otherwise I have no idea what would go in RW sections.)"
    You are both right and not right.
    Remember that the image might be initially stored in some nov-volatile area (e.g., ROM).
    Where is that static initialised variables stored?
    Answer: It will be stored as part of the image in that non-volatile area and copied from there to the volatile area (e.g., RAM) as part of the startup code.
    The linker takes all the initialised data that exists in the RW section and automagically adds some code to the executable.
    The linker might choose to compress this data or not. Also, if there is ZI data, it might simply put a size for those areas - The startup then does a block fill of 0x00 for these areas.
    Well, that's a swift and rather basic description of what occurs.
    It is the position of the data that the linker creates in the executable image which I refer(red) to.
