LPC2148 using 2 UARTs at a time
I want to interface MCB2140 with a pressure sensor which will give input for every 1 second.. I connected UART0 to pressure sensor output, UART1 to serial port of PC. The pressure sensor gives the integer value as output.The UART0 will receive data from sensor and should display in hyper terminal for every 1 minute..I wrote the following code..The code gets hanged in startup file at BX R0...Please let me know any other changes required
#include <LPC21xx.H>
void init_serial (void);
int main(void) {
init_serial();
while(1)
{ int getc_serial0;
int putc_serial1;
void init_serial (void) {
PINSEL0 = 0x00050005;
U0LCR = 0x00000083;
U0DLL = 98;
U0LCR = 0x00000003;
U1LCR = 0x00000083;
U1DLL = 98;
U1LCR = 0x00000003;
int getc_serial0(void)
while (!(U0LSR & 0x01));
return U0RBR;
int putc_serial1(void)
while (!(U1LSR & 0x20));
U1THR=U0RBR;
return (U1THR);
0
