I want to interface MCB2140 with a pressure sensor which will give input for every 1 second.. I connected UART0 to pressure sensor output, UART1 to serial port of PC. The pressure sensor gives the integer value as output.The UART0 will receive data from sensor and should display in hyper terminal for every 1 minute..I wrote the following code..The code gets hanged in startup file at BX R0...Please let me know any other changes required #include <LPC21xx.H> void init_serial (void); int main(void) { init_serial();
while(1) { int getc_serial0; int putc_serial1; } } void init_serial (void) {
PINSEL0 = 0x00050005;
U0LCR = 0x00000083;
U0DLL = 98;
U0LCR = 0x00000003;
U1LCR = 0x00000083;
U1DLL = 98;
U1LCR = 0x00000003;
int getc_serial0(void)
while (!(U0LSR & 0x01));
return U0RBR;
} int putc_serial1(void)
while (!(U1LSR & 0x20));
U1THR=U0RBR;
return (U1THR);
I already posted my code and the startup.s file. When i am using simulation of the code and debug , the code hangs at BX R0
; Enter the C code IMPORT __main LDR R0, =__main BX R0
when i click the stop button the code goes to the SWI_Handler B SWI_Handler and code hangs at this point continuously. Please anyone help me out
"I already posted my code and the startup.s file. When i am using simulation of the code and debug , the code hangs at BX R0"
Well ... it's highly unlikely that the BX R0 will be jumping to the SWI handler, so you need to single step into the BX R0 and see where that takes you.
I am doing single step only and the code always wait at BX R0 continuously. After clicking stop code execution , it is going to SWI_Handler B SWI_Handler and the code hangs there
"I am doing single step only and the code always wait at BX R0 continuously"
I would think you're doing it while the source code window has focus. Enable the disassembly window, give that the focus and step into it there.
Even though i will single step in disassemble, the code hangs in 3 lines continuously. I think i cannot know the exact bug when i use disassemble window also
What three lines?
And no register that counts down in these three lines?
As suggested by the IB Shy, i enabled the disassemble window and did single step. Below code is the taken from disassemble window.
0x00000190 E2522010 SUBS R2,R2,#0x00000010 0x00000194 28A10078 STMCSIA R1!,{R3-R6} 0x00000198 8AFFFFFC BHI 0x00000190
It starts from 1st line and then it goes to 2nd line and 3rd line. From 3rd line it will again come to 1st line and this is continuous loop
"It starts from 1st line and then it goes to 2nd line and 3rd line. From 3rd line it will again come to 1st line and this is continuous loop"
And what's R2 doing during this continuous loop?
Put a breakpoint on the following instruction - Does it get to that?
Same problem, after using breakpoints also the code moves over three lines
"Same problem, after using breakpoints also the code moves over three lines"
What do you mean "same problem"?
So you've gone past the three lines of code. Did you then single step further to see what happens?
I have kept a breakpoint at 0x00000190 E2522010 SUBS R2,R2,#0x00000010 , then single step. The code moves over the 3 lines continuously in a loop
How many times did you step the three lines?
And more importantly - didn't you set a breakpoint on the first instruction _after_ the three-line loop?
Westermark, i did not understand what you adviced to do
So, it seems I need to repeat what I asked before:
"And what's R2 doing during this continuous loop?"
That was a hint for you - To see if you'd figure out what the loop was doing.
You need to put a breakpoint at 0x0000019C (i.e., on the following instruction) to see if it gets there. If it does, then you're past your continuous loop and you can single step further.
Till now i did not got to know, what is the need of changing the startup code?. Is there any bug in my application code or startup file.
