Hello, my group is using an MCB1700 board. The board contains a 16B FIFO buffer size for the uarts. When I send a string across a wifly device to the uart that is 16B or greater we run into issues. Is there a way to combat this? Or should I simply shorten my commands. Here is my uart0 interrupt handler code (part of it). Uart0 is what receives the data from the wifly serial device at a rate of 115200 baud.
NVIC_DisableIRQ(UART0_IRQn); /* disable UART0 Interrupt */
while( (LPC_UART0->LSR & 0x01) ) { command[count] = SER_getChar(0); count++; }
LPC_UART0 ->FCR |= 2; // reset FIFO LPC_UART0 ->FCR &= ~(2);
Is there a way to receive the data from uart0 into command, and keep receiving even after 15 or 16B of data have been transmitted?
