Hi,everybody, I am facing a problem now. I want to specify a veriable in big endian while the whole memory in little endian. You know,it is very easy to achieve this in IAR toolchain by adding a keyword __big_endian, when defining the veriable, but how can i do in MDK? Thanks!
I'm afraid, the RealView compiler does not have such facility. You'll have to do it the traditional way: define htonl(), ntohl() and others and use them where appropriate.
Go to 'Options for Target - Target' and check or uncheck the 'Big Endian' checkbox as required. Note that this checkbox is present/enabled only when the selected MCU device supports endianess configuration.
But any "Big Endian" checkbox will not allow a program to have some variables big-endian and some little-endian.
