I have a negative effect while using UDP for sending data between my controller (NXP LPC2368)and PC. I use not the RTOS (anyway with RTOS i had the same problem)! I using two sockets with different portnumbers - one for receiving - one for transmitting. In my UDP-callback I use no routines like udp_get_buf() or send_udp(). In the UART-ISR I send data to the PC (~2,5 MBit) using udp_get_buf() and udp_send().
The bandwith-, RAM- and CPU-usage is not to hard at all (using GPIO to measure the CPU-usage of each routine).
Everything is working very well as long as I send (2,5MBit) and receive(1kBit) not simultaniously! I this case the system runs well for some seconds and fail with "ERR_MEM_ALLOC" in "void sys_error()" (part of Net_Config).
I tried different settings for Stack- and Heap-Size and the usage of RTOS - allways the same.
The important parts of my source:
__irq void UART1_ISR(void) { ... datasendbuf = udp_get_buf (6+(40*12)); memcpy(datasendbuf,"^GMC",4); ...(memcpy)... } udp_send (udp_soc1, GMC_remip, GMC_port, datasendbuf, 6+(40*12)); ... VICVectAddr = 0; //Acknowledge Interrupt } U16 udp_callback (U8 socket, U8 *remip, U16 port, U8 *buf, U16 len) { U8 *sendbuf; char rx; short x; if(socket == udp_soc) { //Interpreter x=0; while(x<len) { rx = buf[x]; //Buffer Zeichenweise auslesen x++; if(rx=='^') //Auf Startzeichen prüfen { rx_start = 1; rx_CR = 0; udp_in_pointer = 0; } if(rx_start) { udp_in[udp_in_pointer] = rx; //Daten in Puffer übernehmen udp_in_pointer++; if(rx_CR) { if(rx == '\n')//Warten bis Endekennung empfangen { //Befehlshandler if(!strncmp(udp_in+1,"GMC",3)) { SMP = 0; GMC = read_RS232_int(udp_in+4,4); memcpy(GMC_remip,remip,4); GMC_port = port; } else if(!strncmp(udp_in+1,"GCH",3)) { //Comming soon } } } else { if(rx == '\r')rx_CR=1; } if(udp_in_pointer==255) { rx_start = 0; } } } } return (0); } void init (void) { init_mcu (); init_variables(); Timer_Init() ; init_TcpNet (); read_settings(); //UDP-Socket for transmit udp_soc1 = udp_get_socket (0, UDP_OPT_SEND_CS | UDP_OPT_CHK_CS, udp_callback); if (udp_soc1 != 0) { udp_open (udp_soc1, 0); } //UDP-Socket for receive udp_soc = udp_get_socket (0, UDP_OPT_SEND_CS | UDP_OPT_CHK_CS, udp_callback); if (udp_soc != 0) { udp_open (udp_soc, 11000); } } int main (void) { init(); while(1) { timer_poll(); main_TcpNet(); } }
Thanks for your comments!
So you have both a main loop and an ISR that uses the TCP/IP stack.
What is your view on the two last bullets on this page: www.keil.com/.../rlarm_tn_using_withkernel.htm
It works!
I use a flag which I set in my ISR. I poll this flag in my main routine and send all datas from this single point (using a queue).
Thanks a lot.
