I am creating the MAKELONG, HIWORD, LOWORD like in Window's C programming.
However, when I create the macro's below I get the error message that follows.
Anyone have any suggestions on why ARM is complaining? I've never had an issue with standard C with this type of macro before.
I thought that maybe the compiler did not know what type of variable "val" was, so I defined the variable in the macro (long val) but that did not help either.
#define MAKELONG (x,y) ((((x) << 16) & 0xFFFF0000) + (y)) #define LOWORD (val) ((val) & 0xFFFF) #define HIWORD (val) (((val) >> 16) & 0xFFFF)
Source\message.c(23): error: #20: identifier "x" is undefined Source\message.c(23): error: #20: identifier "y" is undefined
Usage of macro:
lCmd = MAKELONG ((0xFFF1), (0x111F));
Just a question for you.
The preprocessor is a "dumb" search/replace engine.
How will a preprocessor know that (x,y) is the arguments of a macro and that the information following on the line is the replace rule?
Note that you have written:
What do you think happens if you rewrite that line as:
#define MAKELONG(x,y) ((((x) << 16) & 0xFFFF0000) + (y))
Do you see any difference between the two lines? Does it surprise you, or is it actually quite logical - if you consider exactly what capabilities the preprocessor has (and hasn't)?
