asm c variable to a assembler register
hi i start a new try.
i am looking for a solution that uVision4 accept to put Variables(Parameters) of c-Code in to Asssembler Registers.
A reference to the "C166 User's Guide - Reference ASM" helped my not because this(my) problem isnot treated!
_inline int vf_control( int offset, int slew, int anglespeed)
        int retvalue;
#pragma asm     ( @w1=offset, @w2=slew, @w3=anglespeed, @4,@5 )
        mov     MCW,#0600H
        mov     @5,ZEROS
        CoMUL   @w2,@w3
        CoSHL   #8
        CoADD   @5, @w1
        CoSTORE @4,MAS
#pragma endasm (retvalue = @4 )
        return retvalue;
  • please just restructe my code that it work's.
    A reference to the "User's Guide" is not what i am looking , i read many of them.
  • This is Tasking syntax - C166 uses a different approach.
    You might try out this version of your code:
    #pragma MODV2
    #include <reg167.h>
    static _inline int vf_control( int offset, int slew, int anglespeed)  {
      int     retvalue;
      unsigned int  zv;
      retvalue = 0;
      zv       = 0;               ; // @5,ZEROS
    //#pragma asm     ( @w1=offset, @w2=slew, @w3=anglespeed, @4,@5 )
      __asm  {
        mov     MCW,#0600H
    //  mov     @5,ZEROS          ; --> zv = 0
        CoMUL   slew,anglespeed   ; @w2,@w3
        CoSHL   #8
        CoADD   zv,offset         ; @5, @w1
        CoSTORE R4,MAS            ; @4,MAS
        mov     retvalue,r4
    //#pragma endasm (retvalue = @4 )
      return (retvalue);
    int   offs, slew, aspeed;
    int     vr;
    void test (void)  {
      vr = vf_control (offs, slew, aspeed);
  • At first thanks a lot! :-)
    #pragma MODV2
    #include <reg167.h>
    The second row is a header file -ok.
    But the first row?
    Why are this two rows are needed?
    I use XE164f Microchip do i need maybe an other header file?
    In the program there are more Assembler/C functions do i have to add more #pragma lines or an other header file?
    For exampel?
    _inline int  pt1_controller32( PT1_array *pt1_parameter, int X)
            int retvalue;
    #pragma asm     (@w1 = pt1_parameter,@w2 = X ,@3, @4, @5, @6, @7)
    _inline int clarke_trans(int Phase_s, int Phase_t, int *ia)
    int retvalue;
    #pragma asm(@w1 = Phase_s,@w2 = Phase_t,@w3 = ia, @4,@7,@8)
  • #pragma MODV2 - I just used this for the example code outside of any
    uVision project. For files of a uVision project, MODV2 will be supplied
    automatically via the compiler command line - it enables the MAC unit of the XExxx type of controllers.
    In your case, the include file is 'XE164F.h', no other headers are required.
    Your functions containing '#pragma asm (@w1...)' need to be ported to use
    the C166 syntax - __asm { } etc. The modified code of the mac function
    'vf_control()' provided earlier should serve as a template on how this is basically done.
  • Ok i get it Thank you!
    But i have still some more problems white a whole assembler file "start.asm".
    I would like to use uVision because of the great diagnostic tools in the debug mode, but it will not like i like to.
    start.asm(12): error: identifier "$EXTEND2" is undefined
    $EXTEND2
    start.asm(13): error: expected a ";"
    $GENONLY
    $EXTEND2
    $CASE
    $GENONLY
    $NOLOCALS
    $CHECKCPU16
    $CHECKBUS18
    $NOMOD166                               //; disable the internal set of SFRs
    $STDNAMES(regxe164f.def)                //; define SFRs
  • In the Tasking help is the following explanation.
    EXTEND2
    Enables support for the CX16x / SUPER-10 architecture,including support for the MAC co-processor.
    i don't no why uVision donot like it.
  • you need to understand that the Tasking and Keil implementation of the 166-tools is completely different: Tasking - EXTEND2 --> Keil - MODV2; uVision will never accept EXTEND2.
    The next problem will be with all those @SET(...), @_CALL(...) etc. macros used in the assembly language file. This needs to be converted to use the Keil macro format. Also 'LDAT' needs to be converted.
    I would suggest to use c:\keil\c166\lib\Start_v3.a66 as a reference for porting, this is the standard startup file used by uVision when creating a XExxx application.
  • A small problem ;-) i hope so...
    CoSTORE [@w4],MAS
    transform to
    CoSTORE [rw4],MAS
    don't work, Keil uVision4 don't know this syntax "rw4" for a word regiester.
    _inline int inv_park_trans(int i_d,int i_q,int phi,int *o_b)
    int retvalue;
    # pragma asm(@w1 = i_d,@w2 = i_q,@w3 = phi, @w4 = o_b , @5, @7, @9, @8)
            mov     @7,MCW
            mov     MCW,#0600h
        shr     @w3,#6
        shl     @w3,#1
        EXTS    #SEG (_sincostab),#2
        mov     @9,[@w3 + #SOF(_sincostab+512)]
        mov     @8,[@w3 + #SOF(_sincostab)]
        CoMUL   @w1,@9
        CoMAC-  @w2,@8
            CoASHR  #2
        CoSTORE @5,MAS
        CoMUL   @w1,@8
        CoMAC   @w2,@9
            CoASHR  #2
        CoSTORE     [@w4],MAS
            mov     MCW,@7
    #pragma endasm(retvalue = @5 )
    return retvalue;
  • I found the solution, its ok. @w4 = o_b
  • What is the problem now? Its typical c-code. The same in other files.
    #ifndef _SUBROUTINES_FOC_H_
    #define _SUBROUTINES_FOC_H_
    Subroutines_FOC.H(646): warning: last line of file ends without a newline
    #endif // #endif _SUBROUTINES_FOC_H_
    Controls_FOC.H(170): warning: last line of file ends without a newline
    Scheduler.H(489): warning: last line of file ends without a newline
    t end of source: internal error: assertion failed: copy_from_source_to_asm_func_buffer: bad lexical escape (D:\edg\src\lexical.c, line 6205)
    It's exactly what it says:
    How hard can that be to understand?
  • just an enter in all last lines of the c-code it did it!
