Keil MCB2300 RTC problem
I want to switch on the LEDs after 3 seconds using the RTC
This is my initialization
int main(void)
{ init_io();
PCONP |= 0X200;
FIO2CLR = 0x00; RTC_CCR = 0x12; //ctc reset and select RTC clock from 32 RTC_ILR = 0xFF; //Clear RTC interrupt register RTC_AMR = 0x000000FE; //Enable seconds alarm RTC_ALSEC = 0x00000003; //set alarm register for 3 seconds RTC_CISS = 0; //Disable all subsecond interrupts RTC_CCR = 0x11; //Enable RTC RTC_CIIR = 0x01;
VICVectAddr13 = (unsigned)isr_rtc_event; VICVectCntl13 = 13; VICIntEnable = (1<<13);
void isr_rtc_event(void) __irq
{ if(RTC_ILR &= 0x00000001) {
FIO2SET = 0XFF;
RTC_ILR = 0x00000001; rtc_update = 1; }
VICVectAddr = 0x00000000;
What I thought is that after 3 seconds the interrupt will be fired and the LEDs will light but this does not seem to be happening. Does anyone know where im going wrong
