Compilation error
Hello I have an error compiling this code :
int RomInSet (const struct GameDriver *gamedrv, const char* hash)
        const struct RomModule *region, *rom;
        region = rom_first_region(gamedrv);   //__RC à supprimer
        for (region = rom_first_region(gamedrv); region; region = rom_next_region(region))
                for (rom = rom_first_file(region); rom; rom = rom_next_file(rom))
                        /* Compare all the available checksums */
                        if (hash_data_is_equal(ROM_GETHASHDATA(rom), hash, 0))
                                return 1;
        return 0;
the error is :
HardPinMameSrc\audit.c(85): error:  #167: argument of type "const struct GameDriver *" is incompatible with parameter of type "const struct GameDriver *"
HardPinMameSrc\audit.c:         region = rom_first_region(gamedrv);   //__RC à supprimer
HardPinMameSrc\audit.c:                                   ^
HardPinMameSrc\audit.c(86): error:  #167: argument of type "const struct GameDriver *" is incompatible with parameter of type "const struct GameDriver *"
HardPinMameSrc\audit.c:         for (region = rom_first_region(gamedrv); region; region = rom_next_region(region))
this code compile without error with visual c++.
can you help me ?
thanks
best regards
Renaud
  • Err, maybe you're using a C compiler now...? No inheritance->implicit type conversions between structs/classes etc....
  • can you help me ?
    Nobody can, because your description of the problem is critically incomplete.
    Where is the definition of struct GameDriver supposed to be? Which lines of your out-of-context snippet are 85 and 86? Where is the declaration of rom_first_region?
    Your problem most likely has nothing to do with C++, nor MSVC. It is that the definition of that struct was not visible at the point that snippet was compiled.
    Oh, and could you really not think of any better title for your post than "Compilation problem"? That would match about half the entire topic range of this forum!
  • Hello,
    Sorry for the imprecision, i'm a beginner..
    here's the code :
    00 #include "driver.h"
    01 #include <stdarg.h>
    02 #include <string.h>
    03 #include "audit.h"
    04 #include "harddisk.h"
    05 #include "common.h"
    82 int RomInSet (const struct GameDriver *gamedrv, const char* hash)
    83 {
    84      const struct RomModule *region, *rom;
    85      region = rom_first_region(gamedrv);   //__RC à supprimer
    86      for (region = rom_first_region(gamedrv); region; region = rom_next_region(region))
    87              for (rom = rom_first_file(region); rom; rom = rom_next_file(rom))
    88                      /* Compare all the available checksums */
    89                      if (hash_data_is_equal(ROM_GETHASHDATA(rom), hash, 0))
    90                              return 1;
    91
    92      return 0;
    93}
    The structs defs : (in "common.h")
    /* ROM processing */
    int rom_load(const struct RomModule *romp);
    const struct RomModule *rom_first_region(const struct GameDriver *drv);
    const struct RomModule *rom_next_region(const struct RomModule *romp);
    const struct RomModule *rom_first_file(const struct RomModule *romp);
    const struct RomModule *rom_next_file(const struct RomModule *romp);
    const struct RomModule *rom_first_chunk(const struct RomModule *romp);
    const struct RomModule *rom_next_chunk(const struct RomModule *romp);
    void printromlist(const struct RomModule *romp,const char *name);
    from "driver.h"
    struct GameDriver
            const char *source_file;        /* set this to __FILE__ */
            const struct GameDriver *clone_of;      /* if this is a clone, point to */
        /* the main version of the game */
            const char *name;
            const struct SystemBios *bios;  /* if this system has alternate bios roms use this */
        /* structure to list names and ROM_BIOSFLAGS. */
            const char *description;
            const char *year;
            const char *manufacturer;
            void (*drv)(struct InternalMachineDriver *);
            const struct InputPortTiny *input_ports;
            void (*driver_init)(void);      /* optional function to be called during initialization */
        /* This is called ONCE, unlike Machine->init_machine */
        /* which is called every time the game is reset. */
            const struct RomModule *rom;
    #ifdef MESS
            void (*sysconfig_ctor)(struct SystemConfigurationParamBlock *cfg);
            const struct GameDriver *compatible_with;
    #endif
            UINT32 flags;   /* orientation and other flags; see defines below */
    and the error :
    compiling audit.c...
    HardPinMameSrc\audit.c(188): error:  #167: argument of type "const struct GameDriver *" is incompatible with parameter of type "const struct GameDriver *"
    HardPinMameSrc\audit.c: HardPinMameSrc\audit.c: 0 warnings, 3 errors
    I hope that someone can help me...
    thanks
    Renaud
  • in "common.h"
    struct RomModule
            const char *_name;      /* name of the file to load */
            UINT32 _offset;         /* offset to load it to */
            UINT32 _length;         /* length of the file */
            UINT32 _flags;          /* flags */
            const char *_hashdata; /* hashing informations (checksums) */
  • Unfortunately the description is still somewhat incomplete, but that's because this error is tricky enough that it's hard to know what's necessary to know and what isn't.
    Note how the error message claims a
    conflict between two datatypes, but prints the exact same string to describe those
    types. That implies that this exact same string must have had two different meanings at
    different points of the compiled source.
    By far the most likely ways for that to happen are if
    a) at least some part of the code (e.g. the prototype of rom_first_region()) referred to struct
    GameDriver before that struct was actually defined, or
    b) you included the definition of struct GameDriver multiple times, but it expanded to different
    structures, e.g. because the MESS macro has switched states in between.
    Your best bet right now is to boil down your problem case to the smallest possible example case
    you can come up with. Replace all #includes by their respective files, remove all parts that
    leave the error message intact. Go on until every single line contributes to the problem. If
    the problem isn't self-evident by then, post the remaining example case here.
