Can't assign values to array I just made.
I can't seem to access the arrays I have made: 'buff' and 'Time'. I am even unable to initialize them. I am watching the locals and the variables 'i' and 'TimeVar' show changes, but nothing seems to affect the arrays.
Problem:
  // Variables
  //-- THE FOLLOWING WORKS JUST FINE --//
  s8  i       = 0;
  s32 TimeVar = 0;
  //-- THE FOLLOWING DOES NOT INITIALIZE THE ARRAYS --//
  s8  buff[4] = { 0, 0, 0, 0 };
  s8  Time[6] = { -1, -1, -1, -1, -1, -1 };   // { ss, mm, hh, dd, MM, yy }
  // I know I'm doing something a little weird here, but this is not causing my
  // my problem, I added this trying to figure out why it is not working.
  for (buff[0] = 4; buff[0] > 0; buff[0]--) // Clear the buffer
    //-- HANGS HERE --//
    buff[buff[0] - 1] = 0;
Complete function:
 * Function Name  : SetRTC
 * Description    : Sets the realtime clock baised on the 12 byte command input
 * Input          : "ssmmhhddmmyy"
 *                  "ss" - Seconds  ["00" to "59"]
 *                  "mm" - Minutes  ["00" to "59"]
 *                  "hh" - Hours    ["00" to "23"]
 *                  "dd" - Day      ["01" to "31"]
 *                  "MM" - Month    ["01" to "12"]
 *                  "yy" - Year     ["09" to "99"]
 * Output         : Displays an error message if it parses unexpected values
 * Return         : 0 - Error, RTC not set
 *                  1 - Success, RTC set
 * Notes          : The time is represented as the number of seconds after
 *                    00:00:00 Jan 1, 2000
 *  Example       : "M361014251011"
 *                  Time - 14:10:36 (2:10:36 pm)
 *                  Day  - 25 October 2011
 *                  RTC Value - 372,867,036 == 1639 7FDC
int SetRTC(char *cmd)
  // TODO: Should these be #define?
  const short RTC_MIN[6] = {  0,  0,  0,  1,  1,  9 };
  const short RTC_MAX[6] = { 59, 59, 23, 31, 12, 99 };
  const short MONTH_TO_DAY[12] = { 31, 28, 31, 30, 31, 30,
                                   31, 31, 30, 31, 30, 31 };
  // Variables
  s8  i       = 0;
  s32 TimeVar = 0;
  // Parse command string
  for(i = 0; i < 6; i++)
    memcpy((&buff[0]), cmd + (i * 2), 2);  // Copy two digits from command to buffer
    Time[i] = atoi(&buff[0]);         // Convert buffer to ineger
    if ((Time[i] < RTC_MIN[i]) || // Check min/max values
        (Time[i] > RTC_MAX[i]))
      printf("\r\nbad RTC date"); // Display error message
      return No_Commands_Run;     // Return without setting RTC
  // Verify the specified month actually has the specified days
  if (MONTH_TO_DAY[Time[4]] >= Time[3])
    if ((Time[4] == 2) && (Time[3] == 29) && (Time[5] % 4 == 0))
      // February 29th of a leap year, not an error
    else
  // Calculate the easy ones:
        TimeVar = Time[0]             +  // Seconds
            Time[1]      * 60   +  // Minutes
            Time[2]      * 3600 +  // Hours
           (Time[3] - 1) * 86400;  // Days
  // Add days for earlier months in the year
  for (i = Time[4] - 2; i >= 0; i--)
    TimeVar += MONTH_TO_DAY[i];
  // Add years for previous years since 2000;
  TimeVar += Time[5] * 365 * 86400;
  // Add leap days
  if(Time[4] <= 2)  // If it is Jan or Feb, hold back a year (see next comments)
    TimeVar += ((Time[5] + 3) / 4) * 86500;   // 2000 = +0 leap days
  else
    TimeVar += ((Time[5] + 4) / 4) * 86500;   // 2000 = +1 leap day
  // Set the clock
        RTC_Configuration();     // Initialize RTC
        RTC_WaitForLastTask();   // Wait for command to complete
  RTC_SetCounter(TimeVar); // Set RTC
  // TODO: Remove after testing
  ReadRTC();
  return Single_Command;
  • What happens when you have a for loop, where your "last" iteration have value 1 in the loop element.
    You then assign 1-1 = 0 to that element, and then perform a -- operation on the element.
    You finally perform new check if element is zero - do you think you will ever see your loop variable reach zero?
    memset(buf,0,sizeof(buf)) is a quite good method to zero a buffer. Why not use it.
    Or using a "real" loop variable. With a "normal" loop variable, the compiler can make use of processor registers, producing smaller code and optionally not have to allocate any memory for the loop variable. When abusing an element of the array as a loop variable, the compiler must produce much worse code.
    Never try "clever" code unless you are very skilled and know exactly what happens. "clever" code will almost always come back and haunt you.
    Working code always wins over "clever" code that is buggy.
  • Sorry, I knew I should have took that "clever" piece out before I posted because it would distract from the issue. The problem I am having is not caused by the for-loop. Even when I do something straight forward I still can't modify the values. Example:
    void func (void)
      s8 buff_1[4];
      s8 buff_2[4] = { 0, 0, 0, 0 };  // Does not work
      buff_1[0] = 0;  // Does not work
      buff_1[1] = 0;  // Does not work
      buff_1[2] = 0;  // Does not work
      buff_1[3] = 0;  // Does not work
    I've messed around with other ways of creating arrays which work just fine, but I can't get locally declared, non-static arrays to work. On a possibly related note, even structures don't like being declared locally:
    typedef struct {
      u8 Second;
      u8 Minute;
      u8 Hour;
      u8 Day;
      u8 Month;
      u8 Year;
    } DateTime;
    void func (void)
      s8  i        = 0;
      s32 TimeVar  = 0;
      s8  *buff;
      s8  buff2;
      static s8 buff3 = { 0, 1, 2, 3}; // Works
      s8  Time[6]  = { -1, -1, -1, -1, -1, -1 };  // Does not initialize
      DateTime theTimeIs;
      buff = (s8 *)malloc(4);
      buff[0] = 0;   // Works
      buff2[0] = 0;  // Does not work
      Time[0] = 0;   // Does not work
      theTimeIs.Year = 11; // Does not work
  • How certain are you the compiler didn't outsmart your code and simply optimize those variables out of existence?
  • I am confident those variables haven't been optimized out because in the compiler I set the optimization level to 0, "No optimization". I also use the variables later in the function to hold a string, then send the buffer to atoi to convert it into an integer that is then used to update the real-time clock.
    If I change my local arrays to static arrays, then the function will work. If I remove the static keyword, then the function hangs on the first read from local array.
    This code is working:
      static const s8 RTC_MIN[6] = {  0,  0,  0,  1,  1,  9 };
      static const s8 RTC_MAX[6] = { 59, 59, 23, 31, 12, 99 };
      static const s8 MONTH_TO_DAY[12] = { 31, 28, 31, 30, 31, 30,
      // Variables
      s8  i       = 0;
      s32 TimeVar = 0;
      static s8 buff[4];
      static s8 Time[6];   // { ss, mm, hh, dd, MM, yy }
        // If buff is NOT a static array:
        //TimeVar = 0;        // Works fine
        //buff[0] = 10;       // Doesn't change buff[0], but doesn't cause program to hang
        //TimeVar = buff[1];  // Causes program to hang
        memset(buff, 0, sizeof(buff));  // Clear the buffer
        memcpy(buff, cmd + (i * 2), 2);  // Copy two digits from command to buffer
        Time[i] = atoi(buff);         // Convert buffer to ineger
      if (MONTH_TO_DAY[Time[4]] < Time[3])
        else
      for (i = Time[4] - 1; i >= 0; i--)
      // Add leap days
      else
      // Set the clock
      ReadRTC();
  • What do you mean by "Does not work"?
    Are you indicating the value is not zero in those locations? Or is that statement not getting executed?
    Does the following "work" for you?
     s8 buff_1[4];
      s8 buff_2[4] = { 7, 7, 7, 7 };
      buff_1[0] = 7;
      buff_1[1] = 7;
      buff_1[2] = 7;
      buff_1[3] = 7;
  • @Marc
    No, that doesn't work either. What I mean is that when the arrays are created they have random values. If I try to initialize them their values don't change, they are still random values.
    s8 buff_1[4];                   // Will have values like { 0x28, 0x32, 0x00, 0x00 }
    s8 buff_2[4] = { 0, 0, 0, 0 };  // Doesn't work, buff_2 will still have random values
    buff_1[0] = 0;    // Still shows up as it's initial value, not 0
    buff_1[1] = 1;    // Still shows up as it's initial value, not 1
    buff_1[2] = 2;    // Still shows up as it's initial value, not 2
    buff_1[3] = 3;    // Still shows up as it's initial value, not 3
    if (buff_1[0] == 0)  // Debugger stops on this line. 'Step', 'step over',
    {                    // and 'step into' don't leave this line
      ... // Do something
  • Hello,
    This sounds strange to me. Are you doing anything 'different' with your memory or start-up?
    For example where is your stack located?
    Is the c-library properly initializing the ZI regions?
    What does you s8 definition look like?
    Are you using any 'special' compiler options? (like --c99?)
  • I think the arrays gets stored in non-existing RAM, while smaller data are stored on stack or in registers.
    Does the OP run his program on a simulator or the real thing?
