Problem with Flash memory Read Protection
We have a problem with disable a Read Flash protection inside our application with the STM32F103RG.
We arrive in a situtation that the flash memory entire in a Read Protection state because there was a power supply failure. After a power reset, the system is in Flash Read Protection and we would like to disabled this protection without Flash Loader software and without to do an erase mass.
How can we do that ?
Can everybody help us ?
Thanks,
  • We arrive in a situtation that the flash memory entire in a Read Protection state because there was a power supply failure. After a power reset, the system is in Flash Read Protection
    sounds strange, which chip?
    the whole point in protection is that you can't disable it "without to do an erase mass" otherwise it would be worthless.
  • .... the chip is a STM32 and there has been no reports of it going into read protect by a power cycle.
    for which you have no need if you have the source. The likelyhood that you legally should be able to 'suck' the code without having the source is infinitessimally small.
  • Thanks for you answer.
    The IC is the STM32F103RG. This situation appear when from IDE uVision or directly from our application you are downloading your program into the flash (writing) and suddently the power is switch off because your input power is failted or another reason. At the next power on, the flash is in the state "Read Protection mode". In this situation in our case, is cathastrofic also because the system when you disable this protection, erase all de flash (mass erase), and because the only way to disbled the read protection is to change the parameter (Options Bytes) with the Flash Loader demonstrator.
    Four our application this way it's impossible to proposal because we have dificult access to the main CPU.
    Thanks,
  • Don't you have a boot loader with suitable functionality programmed into the board? Such a boot loader can normally receive and program a new application even if the flash is read-protected.
    It's normally only when the flash is write-protected that a boot loader can't solve the problem.
  • This situation appear when from IDE uVision or directly from our application you are nloading your programo the flash (writing) and suddently the power is switch off because your input power is failted or another reason. At the next power on, the flash is in the state "Read Protection mode". In this situation in our case, is hastrofic
    this makes no sense whatsoever
    1) how often does the power cut off while you are downloading.
    2) since you can download, a mass erase followed by a download will take care of it - hardly 'catastrophic'
    3) I tried switching power off during a download to a stm32f103 and - lo and behold - the chip did not get read protected, I just repeated the download.
  • Note, Erik, that a mass-erase will also remove any secondary boot loader that the user have added. And that secondary boot loader might be the only way to access the device for adding a new application.
    So a mass-erase is a well working solution for a developer. But may not help with shipped devices.
  • So a mass-erase is a well working solution for a developer. But may not help with shipped devices
    if, indeed, this happens at a "customer upgrade" I do see the issue.
    however, out of curiousity I tried cutting power during a download of the same chip and nothing happened.
    so,
    a) verify sufficient decoupling, whatchdogging etc is in place, as I can not reproduce it.
    b) contact ST directly for advise
  • Yes, I would think that it is common practice that the charge-pumps in the chips holds enough memory to perform one flash write operation on stored power, in which case the chip shouldn't end up in some random lockup state.
  • verify sufficient decoupling, whatchdogging etc is in place
    I have seen strange effects from the above, e.g. I have seen an example where a 3cm trace to the decoupling cap was enough to cause problems. As a general rule, when someone exposes me to something unexplainable I ALWAYS check the decoupling and, if anything is not PERFECT, solder caps directly across the chips. this has "solved the unexplainable" more than once.
  • Hi,
    Well at the end we are foud the problem, I 'm going to try to explian the most clear possibe.
    First of all , we have three ways to programming FLASH memory into ST32M103RG:
    - In Circuit Programming(ICP), with tha JTAG or SWD protocol
    - In Application Programming (IAP), with differents communications channels like UART,USB, etc.., in this cas the CPU must to be in System Memory boot.
    - With intructions in your applicattion like FLASH_ProgramWord, etc..
    With the uVision IDE during downloading the program with JTAG or SWD, if you switch off the power supply, immediately the flash memory change to Read Protection State. The only way to disable the Read Protection is with the Load Flash Demonstrator Software from ST. After to disable the read Protection the FLASH memory is erased (mass erased).
    In the rest of the cases if you switch off the power supply during the programming firmware, the Memory flash state don't change and doesn't happen.
    You can try to do that...
    Thanks for your help,
    Xavi,
