I need to fill data memory both internal and external with known patterns and read back to verify the entire C51 RAM. I prefer doing this in C instead of assembly but have not seen a good example to follow. Any suggestions?
Read this article: www.netrino.com/.../Memory-Test-Suite-C
It describes the types of faults that can occur in memory systems - and why simply filling memory with a known pattern and reading back is not a good test.
It includes 'C' code.
Note that 'C' makes certain assumptions about the execution environment - in particular, that the stack is OK, and any memory used internally and used by your program variables.
So you'll need to verify that in some other way.
Also, if you consider the RAM - particularly the internal RAM - sufficiently unreliable to require testing, is it valid to just assume that the rest of the chip will be fine to run the tests...??
Why is it NOT a good test for data memory?
Many reasons.
1) Capacitive coupling. I can write 0x15 to the data bus but have an address decoding failure so I never manage to activate any RAM memory at the address. The next operation can read back the value 0x15 from the bus, since there are nothing that actively drives the lines high or low.
2) You seldom have broken bits in a RAM memory. But when doing factory tests, you often (in relation to bit errors in the memory) have solder problems that may result in: - aliasing, where multiple addresses actually maps to same address in the RAM - open data lines, where some bits always reads as zero or one (or suffers from capacitive coupling) - connected data lines, where bit x always reads the same as bit x-1 or bit x+1. - ...
So a memory test program must specifically test that all data lines are operating individually. And that all address lines are operating individually. And if address and/or data lines are multiplexed, then the code must perform the tests in a way that the multiplexing doesn't fool the tests into false acceptance.
Testing data lines is often done with walking patterns. 00001 -> 00010 -> 00100 -> 01000 -> 10000 and the inverted variants 11110 -> 11101 -> 11011 -> 10111 -> 01111.
But testing the address lines can be really interesting in a multiplexed scenario where an address line can falsely affect a data line or the reverse and where not only a0 and a1 may be neighbours but a0 and a8 may also be neighbours or even same line.
In the end, a generic test is quite large - too large to be funny to describe in a forum post here. Many simplications are allowed when there is knowledge about the hardware. But it still requires a lot of thought. And if you don't trust the internal RAM, you have to figure out how to perform at least the internal RAM test while making best possible use of the processor registers - remember that the stack and auto variables would assume working RAM ;)
You didn't read the article, did you?
If you had read the article you would, as I said, see the types of failures that can occur in memory systems.
When you understand the types of failures that can occur in memory systems, you will see that many of them will not be detected by simply writing a pattern and reading it back!
I just read the article and trying to justify the requirement for RAM test as part of the BIT test upon MCU power up. The article gets into justification of RAM test for finding production errors like missing chips and or soldering issues and at the end hints at BIT but not in detail. My application here requires BIT to run every time MCU powers up and my concern is that I may corrupt the system parameters written to SFR registers in particular after performing the pattern testing. Any one has tried this?
Why does it require that?
Is this just some regulatory specification, or do you have a "real" reason to do it?
You need to think very carefully about this: how can anything test itself?
We are an Areospace company and this is an instrument intended for flight. The BIT requirement is to catch reliability(MTBF) problems every time the instrument is powered as required by the DO160 test requirement. My job is to make sure I can perform this as intrusively as possible so the question is how to do this safely and reliably?
And you're relying on advice from complete strangers in an unmoderated forum with, essentially, "open" access...?!
"My job is to make sure I can perform this as intrusively as possible so the question is how to do this safely and reliably?"
Surely, an Aerospace company must have staff experienced in this who can help you and, more importantly, will know the specific details, nature, and requirements of the particular equipment that you're working on...?!
Your main quandary should be obvious: if the microcontroller is sufficiently unreliable to require testing, how can you rely upon it to run the test...?
In other words, how do you hope to get a useful test result from a faulty microcontroller?
The safety standards, when devised, rightfully included a memory test, in those days a (ferrite) memory failure was, probably, much more likely than any other failure.
Now approach a person responsible for a safety standard and suggest that something (in this case, the memory test) be removed and see him shake, what if a problem should occur that the removed part of the testing would have caught. You can present Andys (reasonable,justified) argument above till the cows come home, but the test will remain.
Yes - quite possibly so.
But an Aerospace company should have an established way to deal with this...
Thanks guys for all the insight. I agree that an Aerospace should have the requirements in place and allow engineers to work toward meeting them but the situation is not like that where I work. The reason I posted the question in the first place was to get a consensus among us firmware engineers and I already got that.
So in a nutshell, you're trying to determine just how far in over your head you are with this project. Well, the answer is pretty obvious by now: you're in way over your head.
I might be but the consensus told me others might not be far off!
An important aspect here is that whenever external memory is involved, there is the probability of bad solder joints. So it is always good to try to scan all signals that can be scanned to verify correct connectivity.
But the problems are huge.
For example - you turn on the equipment when it is cold. A test when cold does not tell the behaviour after it has been running for a while and reached the steady-state temperature.
Next thing is that smaller microcontrollers often uses 3V3 or 5V and often have most external equipment run with same voltage. More high-end processors normally use multiple voltages. So a very low voltage for the CPU core. A higher voltage for the GPIO signals. A third voltage for the RAM chips. Now, you suddenly got more problems. The reliability of the RAM depends on it getting the correct voltage. With too high voltage, it may get overheated and start to misbehave after a while. With too low voltage, it may run too slowly resulting in too small timing margins resulting in random bit errors. And with incorrect interface voltage between processor and memory you may get incorrect sampling of the high logic level.
So in the end, you have a situation where a startup test often may have a very limited value except to find blatantly broken hardware. In real life situations, safety critical equipment needs to perform constant supervision while delivering the live service it is designed for. So you need to store checksums for all data structures you can get away with and constantly scan through them to verify that they are correct. This not only verifies memory integrity but also verifies that you don't have any bad pointer accesses resulting in memory corruption. After all - the majority of failures an end user is likely to see are from software errors unless you have fouled upp the oscillator or power supply + filtering design.
Obviously, tests designed to run concurrently with the normal operation can't perform any memory tests according to any by-the-book factory tests. You will have to investigate all hw parts and all software modules and create a testability document where you figure out how a running equipment can get a reasonable confidence that everything works as expected. And you will have to figure out what external hardware (watchdogs or whatever) you may need to produce reasonable error messages to the end user in case the system is so broken that it can't perform the normal self-tests and present normal error messages.
A question here is what courses or past experience you have in writing this type of software, where it isn't just enough to make sure an RTOS always manages all required deadlines but where you also needs to supervise all individual actions and all produced output signals and if possible double-check all input signals.
In the end, the device (if the standard so requires) must be designed so that it really doesn't matter how bad the processor or any other hardware is. But the system should either stay pitch black or present a clear error indication in case it can't produce the normal results with the required confidence. Or, for some standards, it may continue to produce results but must then clearly indicate that there are confidence problems.
Are you the only software developer? Note that many of the standards involving human safety are not just happy with "we are doing" but also requires you do produce huge amounts of documentation about all your design steps, reasons for decisions etc, etc. So if you are stuck right now about memory tests, you might get seriously more stuck a while later when the company have invested more money into the product and the reviews redflags your development process, the design, the documentation, the testing, ...
